It is currently Mon Aug 18, 2025 11:13 am
PostPosted: Sun Apr 18, 2010 3:14 pm
Can I please get somone to measure something on a rod change setup for me?
I need a measuremenent from the pivot point of the gear lever (nominal centreline) to the front of the internal crossmember (the face where the seat mounts go).
If I take a stab in the dark I'd be guessing it somewhere in the 5-6 inches range.
Thanks.
:D
PostPosted: Sun Apr 18, 2010 9:49 pm
A template from a rod change car would be the best way???
You're trying to work out where to put the holes for the cotton reel mounts?
PostPosted: Sun Apr 18, 2010 9:59 pm
Not far off.
My deluxe had remote mounting and I'm going the rod.
My holes may be a fraction out from normal because my engine sits tilted forward a bit, but just for playing round at the moment I'm after its mounting location.
Measuring to the stick is better for me as I don't know how I'll make the bracket to hold it yet (exhaust seems to hit).
PostPosted: Sun Apr 18, 2010 10:20 pm
I've got a few with rod changes here you could measure/take a template from, come round and have a look if you like.
Andrew
