It is currently Thu Jul 31, 2025 2:20 pm
PostPosted: Tue Apr 20, 2010 10:12 pm
Ok straight to the point what is better to get more horsepower injection or carb/webber on a mini motor.
PostPosted: Tue Apr 20, 2010 10:14 pm
Depends. Generally speaking the siamese head is the bottleneck for injection, so carby on a 5 port head. If you have an 8 port head things can look the other way though.
PostPosted: Tue Apr 20, 2010 11:03 pm
Most stuff I've seen you can get the same peak horsepower with the carb but the fuel injection makes for a nicer way to get there.
2008 Prado GXL
PostPosted: Tue Apr 20, 2010 11:10 pm
Like what Harley says. If its 5 port then a carb is what you want. For an 8 port/7 port or bimmer twinky then injection is the go.
Siamese port injection is a box you really dont want to open.
Simplify and add lightness
PostPosted: Wed Apr 21, 2010 5:57 am
Mods rock!
A mate has an Escort. He had a Weber on it and had it dynoed. A few weeks later he put Injection on it and went back to the same dyno to have it set up.
The Weber did make more HP, but not by a lot, however the Injection was found to be easier starting (not the the Weber was a problem), smoother all round and better MPG.
Users browsing this forum: Bing [Bot] and 91 guests
