It is currently Sun Aug 03, 2025 11:39 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 141, 142, 143, 144, 145, 146, 147 ... 568  Next
PostPosted: Tue Apr 27, 2010 10:20 pm
Repaired the boot on the mini deluxe over the weekend and then buffed and fitted tonight. Gotta luv a 3 day weekend.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Apr 30, 2010 11:27 pm
Painted the engine and put the clutch back together. Looks good.... So far.
PostPosted: Sat May 01, 2010 7:08 pm
cooper19613 wrote:
polish in readiness for one of 3 cars shows thats on next weekend.
Then took it for a cruise round the beaches at Newcastle.
Which show :?:
Dicko
PostPosted: Sat May 01, 2010 7:11 pm
I found this :shock:
That Bog is about 10mm thick
Dicko
PostPosted: Sat May 01, 2010 7:15 pm
This space for rent
Started my regular 1,500mi service by draining the oil... then realised I don't have any to put back in it :x
Looks like a trip to K-mart is on the cards tomorrow. And I was *just there* today... :roll:
PostPosted: Sat May 01, 2010 7:28 pm
So was I, and we missed each other :!:
Dicko
PostPosted: Sat May 01, 2010 7:36 pm
:roll: :roll: :roll:
Took the engine out once more......
PostPosted: Sat May 01, 2010 8:00 pm
drove her round the block and into my freshly concreted shed .....let the work begin ,,,,, again :D
PostPosted: Sat May 01, 2010 10:29 pm
Tomboss Breweros
Owies :cry:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat May 01, 2010 10:35 pm
Changed the SU dashpot oil from AT fluid to motor oil.
It doesn't sound like much, but there's two SUs. That's four screws.
PostPosted: Sat May 01, 2010 10:42 pm
This space for rent
And what sort of a difference did it make?
PostPosted: Sun May 02, 2010 12:03 am
Took my Triger Crank pulley and front pulley off to a mate to get a spacer machined up. Cleaned a few more angine bits and painted them.. Slowlt getting it back together...
It may all go *BOOM* but it might not :)
PostPosted: Sun May 02, 2010 7:00 am
The Dr made a house call and put two patches in the floor. Then I cleaned out the back of the Van. Next weekend will be the Brassing of the Pin holes then paint it all in classic black
PostPosted: Sun May 02, 2010 9:41 am
With my set up I've been getting a lot of issues around 2800-3200 rpm. Like the mixtures are chopping in and out when the engine is loaded down. It's smoothed it out dramatically, but not removed it entirely. It might be the grade of oil (10-40) which was all I had in the cupboard...
 Post subject: Need head!!!!
PostPosted: Sun May 02, 2010 11:51 pm
Bolted everything that needs to put on the engine (sort of). Still waiting for pulley spacer/belt retainer for cam belt.. Oh AND the head back. Then it can go back on. Should have it in the car by next weekend....
