It is currently Wed Aug 20, 2025 4:27 am
 Post subject: Guess the damage!!!
PostPosted: Mon May 03, 2010 1:25 pm
Travelling over a hour out of Alice Springs for a festival I had almost arrived when I heard squeeking noises like a mouse coming from the front. The steering wheel forced itself to the left. The whole car lurched to the left two feet almost taking me off the highway.
I get to the river and start crossing the sand and then crunch and the whole car again lurched to the left almost keeping me stuck in the sand.
Thought it was inner cv took them apart and put them back together. They looked fine.
Had to drive 100km home with something reasonably large bouncing pretty violently around the bottom end.
To summise. Motor sounds fine standing still. Can still get through all the gears. So what the he'll have I done to the diff.
At a guess have I mashed one of this small gears inside the the hub that bolts onto the crown.
PostPosted: Mon May 03, 2010 1:30 pm
yep, broken spider gear... and now that you've driven the engine that far, eveything else will be rooted too - well done
PostPosted: Mon May 03, 2010 1:53 pm
It didn't sound crunchy bad all the way home. I'm gathering a tooth is bouncing around inside.
I have half a dozen earth magnets on the filter. I have a spare diff. I have spare gearbox parts. As long as the top end is ok I'm in a position to repair it quite easily.
Just sux being 100km in middle of nowhere where your only chance of a tow is a mate with a 4x4.
PostPosted: Mon May 03, 2010 8:36 pm
what do you think the oil pump was picking up while you were driving all that way??
PostPosted: Mon May 03, 2010 9:05 pm
Same happend to me last friday... http://img153.imageshack.us/img153/8990 ... haden2.jpg - doesn't look like much, but the gearbox was full with fine debriss and metal flakes...! I'd strip it down completely for inspection & cleaning.
PostPosted: Mon May 03, 2010 9:08 pm
and deposited all that metal in every bearing,oil gallery. :shock:
has the oil pressure dropped yet
www.minisprintgt.com
PostPosted: Mon May 03, 2010 10:36 pm
Asphalt wrote:
Same happend to me last friday... Image - doesn't look like much, but the gearbox was full with fine debriss and metal flakes...! I'd strip it down completely for inspection & cleaning.
nice... here's mine
PostPosted: Tue May 04, 2010 5:16 am
Nice one! :twisted: Did yours at least last longer than 5000km...? :roll:
PostPosted: Tue May 04, 2010 9:32 am
kinda... they were new, then 12 months later I replaced the diff pin and they were still good, then 5 months after that this one shattered. Probably more like 10,000k's
PostPosted: Tue May 04, 2010 10:14 am
I got it home and parked it, i have organised a workshop, and will be taking the whole motor out and apart. Have everything i need for a rebuild, so will take care to flush everything out completely.
It seemed to run quite smoothly all the way home, excepting the piece that was bouncing around the gearbox. So im hoping theres not too much damage. And still have normal oil pressure, car still runs fine standing still.
I havent driven it since.
PostPosted: Tue May 04, 2010 1:01 pm
Its all in a box you can sort it out later! :lol:
Users browsing this forum: No registered users and 437 guests
