It is currently Mon Aug 18, 2025 5:11 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Sun May 02, 2010 10:27 pm
I have had two Minis in the past with the pump connected. In both cases the increase in power was noticeable but not really significant.
I have been told that the pump costs about 3bhp to the engine, which on a standard 998cc which has a factory listed output of 38bhp is about 8%.
Most people including myself, have removed this pump, which has provided a little more power and considerably greater access to the alternator.
However, as a result, there are very few original Minis getting around that still have this pump fitted. If your car is otherwise in very standard spec, it might be worth considering leaving it is is.
It may not be "working" because of the modern fuels being used, but if it "functioning" in the way it is intended it may make the car historically more significant.
It is of course entirely your decision, so the choice really comes down to if you prefer a little extra power and easier maintenance on the alternator etc, or if you want the car to be historically accurate, or if you want a compromise, as suggested, where you prevent it from operating but keep it in place so it "looks" right.
Watto.
PostPosted: Mon May 03, 2010 8:12 pm
Thanks for that watto.
If I decide to remove the unit, what is the best way to plug up the holes in the head?
1977 LEYLAND MINI SUNSHINE 'S'
PostPosted: Mon May 03, 2010 8:26 pm
Mods rock!
A nice touch is to use cap head style (allen key) grub screws.
You could use hex head bolts or often I've seen the original tube nuts brazed over and screwed back in.
PostPosted: Mon May 03, 2010 10:10 pm
The 4 threads in the head are 7/16 UNF. Grubscrews are expensive as this size ain't popular.
A fairly neat way to plug the holes is screw 4 old seatbelt bolts in there, then cut them off and dress flush with an angle grinder.
PostPosted: Mon May 03, 2010 10:27 pm
if you take it all off, keep everything intact and put it up for sale, someone restoring a car will want it
PostPosted: Mon May 03, 2010 11:16 pm
yeah, especially the gulp valve. How many of us can boast having a gulp valve :P
PostPosted: Tue May 04, 2010 4:42 pm
A gulp valve is a good thing isnt it?
What about the charcoal canister?
PostPosted: Tue May 04, 2010 5:03 pm
Years ago I dismanted the pump on my Gemini and removed the vanes, as well as blocked all the hoses. That way it looked like it was working to the average cop at the roadside. I also had a Weber hidden under the stock airfilter. :lol:
If you drove a Gemini in Sydney in the early 90's, underbonnet inspections were a regular occurence!
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue May 04, 2010 7:08 pm
My sister-in law has a late 77 clubman 998 with the air pump fitted. As everything else on the car is original, we kept it on. It doesn't make the car any slower in comparison to our standard 1100 minis. And as an original shopping cart, it does the job
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
PostPosted: Tue May 04, 2010 9:43 pm
Yeh. I will leave it on simply because everything is original and not modified. I was just interested in what to do if I were to take it off. You never know what might happen down the track if I ever choose rebuild the engine. But for now its fine.
PostPosted: Tue May 04, 2010 11:13 pm
I think in time when everyone starts restoring the late mini's and mokes to standard, the original air pumps will be in demand. As will the pollution heads! :)
PostPosted: Wed May 05, 2010 6:43 pm
Yeah. I'm going to hang on to mine.
PostPosted: Wed May 05, 2010 8:28 pm
That is so correct ...
I'd say he should take it all off and give/sell it to me ...
But id be very biased .. since my car is missing it and it WANTS it back :D
PostPosted: Wed May 05, 2010 9:16 pm
Im afraid you will have to keep looking mate. :D :D :D :D
Users browsing this forum: No registered users and 112 guests
