John Smidt wrote:
owen1975richard wrote:
I think if I was to buy this motor for 2k, I would be fitting it and seeing how it goes before sending it for a strip and possible freshen up. I have a car that had not been started since 1995, it was turned over only. Other than maybe stem seals down the track, it runs great.
If you are going to freshen it up, then I would look around for one that needs a re-build and pay accordingly.
The idea of pulling the Motor Down to check Was suggested, if the motor has been recently rebuilt by an unknown Person, ( this is totally different to an engine that has been sitting for Years ) In the many Years I have been in this business I have unfortunately seen Many Recon - Rebuilt Mini Motors And Gearboxes Assembled by people that do not know what they are doing, even qualified Mechanics With no experience working on Minis, They often buy all good parts but assemble them incorrectly,
a lot of damage could be done which may have been avoided by checking it
John has really hit the nail on the head with a FBH. ANY second hand engine should be stripped and completely check over by some one who knows minis.
just a example , I have a moke with 1275 that a bloke wanted me to check over. The engine was completely re-build by a company here in adelaide. The engine has only done 500km since re-build and is stuffed. Compression down 2 cylinders, burning oil, and had a nasty knocking sound. The cylinders still had hone marks and the pistons had bugger all crap on them. PROBLEM who ever re-bored it stuffed up on the size for No 1&4 cylinders only by .010"
NO matter what 2nd hand engine and what you are told be prepared to spend extra money and get it checked over . It's cheaper than stuffing up a eng/box
Given the motor we are talking about has done 7,000k's, I would try it (each to their own). There are instances of motors not being built properly, no argument there. But would you pull a 7,000km motor out of a car and strip it because someone you didn't know might have built it and got something wrong - No.
