It is currently Tue Jul 29, 2025 3:43 pm
Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Wed May 05, 2010 9:17 am
UPDATE TIME..!!! 8)
So Maysie was collected Saturday 24 April 2010 from her dusty garage corner to be taken to be fixed............
................... sorry thats all the news i have. :cry: I dont think Greig has worked it out either.
PostPosted: Wed May 05, 2010 11:19 am
deluxe_68 wrote:
IwannaMini wrote:
Does anyone have a picture of what the crankshaft sensor looks like? What is this connected to? I am starting to think that maybe the wiring to this sensor may have burned out and hence this sensor is not receiving power full stop.... is this a possibiloity?
It is the sensor behind the starter motor
On an automatic its on the outside of the torque converter housing. Blue square plastic block thing.
PostPosted: Wed May 05, 2010 9:55 pm
you need to know if the crank angle sensor has the correct voltage, and using a tester, check wether it has a pulse while cranking.
There is no module in the dizzy.
the fuel cut switch won't affect spark.
Fault code reader wont tell you.
won't be any of those.
It would be cheaper to put it on a truck and deliver it to my house to find the problem...
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Thu May 06, 2010 2:08 am
The crank angle sensor is mounted on the torque converter cover, down low at the back, with a harness & plug attached to it. My inj 1/2 cut engine would'nt go recently (same as you, no fuel & spark) so I pulled the sensor out and cleaned all the crap of it, and pulled the rubber sleeve back to check the wires were'nt broken, to find a broken wire! I soldered it back on, refitted the sensor and she fired up straight away!
Have a Nice Day.
PostPosted: Thu May 06, 2010 9:23 am
oh... the update = she is now sitting in Greig Malure's workshop....
Hopefully will be fixed soon.
I gave up. :oops:
PostPosted: Fri May 07, 2010 1:09 pm
SHE'S RUNNING SHE'S RUNNING SHE'S RUNNING..!!!!!!!
Not sure what the issue was just yet, but she has fired and run.......................
I feel like a father who's wife has just given birth..!!! :P
PostPosted: Fri May 07, 2010 1:16 pm
ROFL- a boy or a girl?? :P
[edit] now, will it keep on running....
Last edited by drmini in aust on Fri May 07, 2010 3:33 pm, edited 1 time in total.
PostPosted: Fri May 07, 2010 3:01 pm
Contrats!!! : :D
PostPosted: Fri May 07, 2010 5:32 pm
great news!
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Fri May 07, 2010 5:55 pm
Thats great news. I think we are all waiting to know what was wrong.
So when are you putting a carb etc on it or selling it? Or do you love it again.
I always hate my car until its running again....then its like love all over.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Fri May 07, 2010 6:36 pm
bet its something simple thats already been looked at or glanced over and "seemed" fine
PostPosted: Sat May 08, 2010 6:28 pm
ok the offician diagnosis was a fried crank angle sensor.... so replacement one of those and she is back in the garage, happier than ever in millions of pieces.
And Ryan.... i am back to loving her too much to get rid of her.
BUT... if she breaks again. Its $500 to the first person with cash and a tow truck to take her away.
now........... to fix the not working indicators and the overheating problem and put her back together again................... watch this space.
PostPosted: Sat May 08, 2010 8:31 pm
Rover Cooper
where can this little gem be found, just asking for future reference
PostPosted: Sat May 08, 2010 10:08 pm
On Manuals it's behind the starter motor, on auto's it's on the torque converter housing.
