It is currently Wed Jul 23, 2025 10:01 pm
PostPosted: Sun May 09, 2010 2:54 pm
Spent 3 hours at the weekend cleaning the rod shifter box and fitting a KAD shifter. Oh yeah baby...
I've also come to the conclusion that, like all British vehicles, most of the grease and oil appears to be on the outside of items rather than sealed inside! :?
The shifter box only has a metal to metal slider sealing the front and the steel plate in the base has an open drain hole. :shock:
Regards,
Mike
"He who dies with the most toys wins."
PostPosted: Sun May 09, 2010 2:57 pm
Supercharged
so you like fishing then...
PostPosted: Sun May 09, 2010 2:59 pm
Online
It's called `agricultural engineering'.
The factory paid scant attention to the need for lubrication.
PostPosted: Sun May 09, 2010 3:45 pm
That's why he went for a rod change! :D
PostPosted: Sun May 09, 2010 10:37 pm
Tomboss Breweros
Hehe, at least you know if it's going to be an odd or an even gear :roll: :lol: :lol:
kimini wrote:
Jimmyinamini wrote:
 Post subject: kad
PostPosted: Mon May 10, 2010 9:17 am
Weight saving :)
Regards,
Mike
PostPosted: Mon May 10, 2010 9:21 am
Very nice.
Is this car a track car ? The amount of KAD goodies is insane.
PostPosted: Mon May 10, 2010 9:49 pm
looks good, what did you use to clean up the aluimium
PostPosted: Mon May 10, 2010 10:18 pm
Noice!
1978 Leyland Clubman S
PostPosted: Fri May 14, 2010 9:42 am
out of interest, did you re bush it?. When i did mine i turned the rod around, so the warn end was at the front, and rebushed the housing. Made the whole arrangement feel infinitely tighter 8)
--Insert legal disclaimer here--
PostPosted: Fri May 14, 2010 1:30 pm
Are you going to move the whole assembly inside the car? It always looks good and you can see the shiny bits.
Simplify and add lightness
PostPosted: Sat May 15, 2010 5:24 pm
send me the KAD rear trailing arms & disc assys ok? i`ll look after them for you while you fit the shifter :-)
Users browsing this forum: cgo, drmini in aust and 107 guests
