It is currently Sat Aug 02, 2025 1:46 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 149, 150, 151, 152, 153, 154, 155 ... 568  Next
PostPosted: Sun May 23, 2010 6:54 pm
pulled my carby apart and cleaned it because i was driving up the melba highway to kinglake and she died. stupidly i didn't have any tools so i had to get a tow home. was lots of grit and muck in the carby. fitted a new fuel filter and a few bits of new fuel line.
runs much much better now.
PostPosted: Sun May 23, 2010 6:59 pm
kimini wrote:
well after 3 months of whinging and bitching about the door/windows rubbers, i finally got the glass back in both doors now :D !
A little bit dodgy looking in spots (they were a bastard to line up in the passenger side!) but as long as people ignore it when they see it, I'm good :lol: !
Now to fix 10 mm gap in passenger door when closed...................... :roll: !
dodgy looking door line up-FIXED :D !
10mm gap-FIXED :D :D !
Its amazing what persistance and a lot of swearing can do :oops: :lol: !
Cheers, Kim :-)
**purple '68 deluxe!**
***FINALLY wearing number plates----yeaaaaaah baby! ***
PostPosted: Sun May 23, 2010 8:18 pm
Painted fan and alternator, put radiator back in, connected up the hoses and put exhaust on. Hetty is one quiet mini, no rattles or anything.. I is a very very happy lad... onto the interior now.
PostPosted: Mon May 24, 2010 8:55 pm
Re fitted wiring harness, fixed it up at the same time, cut out some additional wiring and soldered it all back up again. Fitted Wiper motor. put on a new accelerator cable.
PostPosted: Mon May 24, 2010 8:59 pm
Refitted the MED balancer to the 1412 yesterday with a longer bolt, Loctite 262 on the bolt and the crank nose.
Now the 1360 motor can come out, once I get a round tuit. They are hard to get though... :lol:
PostPosted: Mon May 24, 2010 10:06 pm
took 3 wheels to be separated from there Tyres
Finally found 5/16 Pipe for the Fuel Line
PostPosted: Mon May 24, 2010 10:12 pm
Tomboss Breweros
Heres the one you are after, they have 7 in stock :wink: A round tuit
kimini wrote:
Jimmyinamini wrote:
PostPosted: Mon May 24, 2010 10:22 pm
such practical stuff on that website - I might buy some of these - out to help me out at Hay
PostPosted: Tue May 25, 2010 7:59 am
Removed remote housing, bolted on lifting lugs to front bulkhead gussets, ready to lift the body off the front subframe/engine assembly. Removed handbrake cable floor seals, ready to release cables and rear subframe.
Al
PostPosted: Tue May 25, 2010 10:25 am
Al
don't forget the f*cking earth lead from the engine :evil:
PostPosted: Tue May 25, 2010 11:16 am
Yeah, nasty one that. Also, the brake light switch leads tucked in under the servo. Thanks Si.
Al
PostPosted: Tue May 25, 2010 5:44 pm
Got the tyres pulled off the clubby rims so I can get them bead blasted.
"Ride hard or die trying"
 Post subject: Woot Woot!!
PostPosted: Tue May 25, 2010 5:55 pm
Got it started and sounds great and its not even tuned yet!!
Last few bits to go and off we drive!
Get ready Cairns!
 Post subject: Re: Woot Woot!!
PostPosted: Tue May 25, 2010 6:07 pm
Get ready Cairns!
fwoar, that looks awesome
 Post subject: !!!!
PostPosted: Tue May 25, 2010 6:16 pm
long way to go before its finished but only alittle before i drive it. will post some pics once driveable!
Users browsing this forum: Bing [Bot] and 104 guests
