It is currently Wed Aug 06, 2025 11:33 pm
PostPosted: Mon May 24, 2010 5:26 pm
Are Morris 1100 fluid displacers the same as Mini ones?
PostPosted: Mon May 24, 2010 5:41 pm
No, they are much larger.
PostPosted: Mon May 24, 2010 6:33 pm
Thanks Morris.
PostPosted: Mon May 24, 2010 6:34 pm
Do you have a problem with one?
PostPosted: Mon May 24, 2010 6:40 pm
Not me, I was asking for a bloke on another forum.
PostPosted: Mon May 24, 2010 8:06 pm
Hi are morris 1100, 1500 and 1800 the same, do any other bmc cars float on fluid Regards Daren
PostPosted: Mon May 24, 2010 8:19 pm
Mods rock!
The Metros had a Hydrogas System. The 'springing' was actually done by a gas (dry nitrogen?) in the 'displacer' and they used hydro fluid to adjust the height. The two fronts were completely independant and the two rears connected together. Conventional shocks were fitted to the fronts however there were none on the rears.
PostPosted: Mon May 24, 2010 8:24 pm
The 1100 and 1500 displacers are very similar, the ends of the hoses are different.
The 1800 uses much larger bags on the front and the same size as the 1100 on the rear.
Other vehicles with hydro (hydrolastic or hydragas) are the Austin 3 litre, the Austin Maxi, the Austin Allegro, the Metro, the Austin Princess/ Ambassador, the MGF and maybe some others that I can't remember off the top of my head.
PostPosted: Mon May 24, 2010 8:51 pm
Going slightly off-track.. but didn't the 1800 have the displacers mounted horizontally?
Would 1800 rear units be good donors to replace sagged/flogged 1100 front ones? (/looks over shoulder for 1800-lovers lynch-mob)
Jacob
