I don't have the A+ ratios handy at the moment...
Helix angle was changed (made steeper) for the A+, so a whole set of gears would be needed. Gear centres in the boxes are the same. Problem is, the 1st gear end of the A+ layshaft, and the cluster gear bearing at that end are both different to normal rod change/4 synchro remote ones.
I'll stick to 4 synchro remote and A series rod change, there are still more parts available either new or s/h.
I've been told the Metro Challenge gearset even in UK is like rocking horse droppings... and s/h ones for sale are probably worn out.
at least you can still buy the normal A series SCCR gearset new, easily from MiniSpares or elsewhere, for around A$1,100..
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
