It is currently Wed Jul 23, 2025 8:06 am
 Post subject: Mini van Q's
PostPosted: Tue May 25, 2010 6:03 pm
Hi guys and girls...
just a few questions about a mini k van...
do i need special carpet or is it just the standard mini sedan?
also is the dash the same as the uk ones or do i need to get one made locally
cheers cam
PostPosted: Tue May 25, 2010 9:36 pm
The carpet is the same as a sedan, except that you only need the front section (infront of the cross member).
What do you mean about the dash exactly?
PostPosted: Tue May 25, 2010 9:42 pm
I f you want you can carpet the rear floor but that section is just under 100mm longer than a sedans rear floor and their is extra metal brackets in a van (for the battery and spare tyre).
The dash rails are basically the same from 1959 to 2001, just the later ones (1970) weren't designed to look nice uncovered.
PostPosted: Tue May 25, 2010 9:59 pm
Are you wanting to restore the Van to original spec, or just wanting to know what carpet fits?
Reason I ask is that Mini K Van did not come with carpet, but had the moulded plastic floor mats. Might be very difficult to find one in good condition.
Leyland Mini Van had carpet - same as sedan, but only front section.
Watto.
:shock:
PostPosted: Tue May 25, 2010 10:21 pm
I fitted a T**-Fit mouled carpet intended for a Mini sedan to my K van (since sold). I had to cut down the rear section to suit. I then used the offcuts to fill the area where the carpet was originally cut to fit around the rear side bins on a Mini sedan. Otherwise it was straightforward, but the fit around the tunnel was crap!
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue May 25, 2010 10:52 pm
I did the same with a T**-Fit in my van.
But yes, the tunnel section fitment is a little, disappointing. :roll:
Image Image
PostPosted: Wed May 26, 2010 4:39 pm
I don't think the K*** auto carpets fit is any better really. I've had both. :lol:
PostPosted: Thu May 27, 2010 4:20 pm
nah it wont be back to ridgey didgey..
i an just going to make it into a tidy little van to drive.
i want to cover the whole floor, inculding behind the seats, so am i better of getting a custom carpet then?
i will also have another one on the goods carrying floor too.
the dash i want to put in a timber dash with gloveboxes and what not... atm all it has is the center speedo and the shelfs....
thanks for the help
cheers cam
