It is currently Wed Jul 23, 2025 5:40 pm
PostPosted: Wed May 26, 2010 10:37 am
Ellow..
Stipid question but how do I know if my Cooper has Hilows fitted ? I was told by Greg ( Mini classics ) that my car has them fitted but now I need to drop the rear by a fair bit but dont know anything about this.
A short walkaround video I shot of my Cooper shows that it sit to high at the rear. I already replaced the dampers for new Spax adjustables ( hard /soft )
http://www.youtube.com/watch?v=zPKObakgeBM
Garth
Its not the size that matters.........
Rover Mini Cooper 1993 spi - current
Rover Mini Cooper 1998 ( Tahti Blue/white)
Rover Mini Cooper 1992 ( Brg),1987 Mayfair
PostPosted: Wed May 26, 2010 11:00 am
Mini's a meant to be higher at the rear, they handle much better with the rear a couple of inches higher at the back.
The dampers you changed will not alter the ride height at all.
But if you don't care about handling and just want it to look good, then the hi-lo's are horizontal at the rear, if you jack it up and take the wheels off you can then undo the locknut and lower the car by winding them in (clockwise) as you count the flats, make sure it's equal on each side.
They look like this, extension bars are at the rear.
Nice car 8)
PostPosted: Wed May 26, 2010 11:15 am
Yeah I know the Dampers will not change the ride hight :?
But...My Cooper has always sat way to high at the rear and thats not normal for Rovers. There actually about the same ride hight.
Hmmm...Might be her in for a sess with Mr Mini !
PostPosted: Wed May 26, 2010 1:40 pm
Rover Cooper
PostPosted: Wed May 26, 2010 2:43 pm
go out, jack it up, take a rear wheel off, and take a photo under the rear arch, showing the trailing arm, trumpet/hi-lo, rubber cone etc... post it here and someone will tell you what you have!!!
If there's a rod with threaded end and a locking nut with a short alloy trumpet mating against the rubber cone, you have hi-los.. if there is just a long trumpet between the knuckle joint and rubber cone, you don't have hi-los
tim
PostPosted: Wed May 26, 2010 11:09 pm
Milatsmadmini
a fat chic in the rear will fix it.
PostPosted: Thu May 27, 2010 1:34 pm
Great help ! Thanks mate will do so on the W/E :lol:
