It is currently Sat Jul 26, 2025 11:11 am
PostPosted: Tue May 25, 2010 10:44 pm
Never heard of the drilling of plugs b4....! Never thought to index mine either. Who would sell the plug washers? Is it of any use on an A-Series?
http://www.ehow.com/how_2343886_index-s ... onomy.html
PostPosted: Tue May 25, 2010 10:57 pm
I dunno, Vizard spoke of it, and I suppose if you are after 10/10ths performance then maybe..
At the bottom of the page however, he has a note that states you should put a high power coil in your old distributor car to provide a hotter spark. He doesn't mention the melting points you will be plagued with if you actually did this to your mini dizzy.
PostPosted: Tue May 25, 2010 11:14 pm
I have to laugh I'v always index mine. i don't know where i got the idea from but i'v always been lucky where I can swap them around and always get them close to center. don't know if it does and difference thou
PostPosted: Wed May 26, 2010 7:41 am
Mods rock!
Looks like a hard way to go about it.
Just use Open Nose Plugs :!:
PostPosted: Wed May 26, 2010 4:36 pm
This plug indexing stuff works in V8s, where the flame front has a long way to go and chamber shape is often not the best.
An A series head has excellent burn characteristics, and I doubt you will see any measurable results.
:idea: Ask GR... he has an engine dyno and I bet he's tried it. :wink:
PostPosted: Wed May 26, 2010 5:15 pm
Has been done, some info here:
http://www.ausmini.com/forums/viewtopic.php?t=4990&postdays=0&postorder=asc&highlight=indexing+plugs&start=30
and a nice explanation here:
http://www.fordmuscle.com/archives/2000/07/indexplugs/index.shtml
I've done it on the race engines (not mini) but do intend doing it on the mini.
Can't hurt, and even 1% will help.
PostPosted: Wed May 26, 2010 6:27 pm
A few blokes that I have spoken to overseas that have done lots of dyno testing on real race engines (F1, Cart, Le Mans, etc) have told me that it does nothing at all.
Buy hey, if it makes you feel better... :lol:
PostPosted: Wed May 26, 2010 6:43 pm
On a real race engine with EFI, multi valves & decent ports I wouldn't expect any measurable diference either, but on older production engines flame front propogation has made a difference. Has been dyno proven on V8 drag cars and Pinto race engines, so I will do it to my mini too - but only after I change to electronic ignition (not much point while running the old "S" dizzy).
PostPosted: Thu May 27, 2010 3:05 am
isn't this drilling idea just the cheap way of getting a Splitfire plug?
PostPosted: Thu May 27, 2010 8:55 am
The drilling idea has been disproved.
