It is currently Sun Aug 03, 2025 1:17 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 151, 152, 153, 154, 155, 156, 157 ... 568  Next
PostPosted: Wed Jun 02, 2010 11:59 pm
finally installed a taco yum :roll: tachometer that reads to 8000 i hope it never gets there :? also my wife brought home some nice material for the headlining and some glue i wonder if she will fit it also :shock:
PostPosted: Thu Jun 03, 2010 8:29 pm
bought some etch primer, clutch master cyclinder, rear window, sand blaster, paint respirator, 202 head, radiator shroud, had one massive clean up day in shed.....
8000rpm, mine goes to 10,000 only i hope to one day reach this as it will most probably mean i have a different engine
PostPosted: Thu Jun 03, 2010 10:22 pm
Went to put in the rear window, but decided I needed to do a little more research as to how to do it... :?:
PostPosted: Thu Jun 03, 2010 11:13 pm
started walking around to the engine bay to do a bit more bitumen removal, knackered myself on a protruding door hinge :oops: , came back inside and got myself a JD & coke. :roll:
PostPosted: Sat Jun 05, 2010 1:48 am
That takes mad skills.... I feel your pain...
Re-fitted front and rear windows. Started on bleeding the brakes but I think the master cylinder may be knackered can't even get fluid to flow out the top of it by putting my thumb over the hole. Time for a new one me thinks.
PostPosted: Sat Jun 05, 2010 2:51 am
Chnaged the front indicators for real glas ones. They look just so much better! 8)
PostPosted: Sat Jun 05, 2010 1:47 pm
Finally got a round tuit and pulled the 1360 out.
Once the engine bay is painted and the rack fitted, I'll drop the 1412 stroker in.
These original Maniflow LCBs seal good on the centre flange..NOT.
And this is after it was dressed flat and parallel with the end ones, 11,000 miles ago.
It didn't come out peacefully either, I had to use the electric LCB removal tool:
PostPosted: Sat Jun 05, 2010 7:06 pm
got new tires for the front 165 70 10ns bridgstone so i should have grip at the front and the rears are nice and old 80% worn so handbreak turns should come easy next weekend :D
love the lcb removal tool :twisted:
PostPosted: Sat Jun 05, 2010 9:09 pm
Funny enough I also collected a set of four 266 today also with a good amount or tread on them also. A Huge thanks to Steve for these Tyres and they will be used to the best of my ability :wink:
Other than that not much but I have put the second set of wheels into the soda bath to remove the paint off them.
Tomorrow will be more work to get the van on the road shortly
Kev is it more the gasket then the manifold :idea:
PostPosted: Sat Jun 05, 2010 10:01 pm
No, the gasket was new, and before I fitted it I bolted the whole LCB to a head (no gasket) and ground/filed all the flanges until I could not fit a .002" feeler in anywhere. (yeah I can file real good, the railways taught me)
My theory is the middle pipe gets hotter under power, expands more (gets longer) than the other, then the flange lifts away from the gasket at the bottom.
On the engine dyno the middle pipe always gets red hot before the others.
When the 1412 goes in, it has a new LCB (also ground/filed flat)- I might get the file out and make the top face looser than the bottom this time.
PostPosted: Sat Jun 05, 2010 10:22 pm
by the sounds of its the gasket could not handle it. Maybe its just a matter of fact to change it 3/4 of the 11,000 or maybe 7,500 and no dramers
PostPosted: Sat Jun 05, 2010 10:39 pm
The gasket is the currently available `big bore' one- IMO it's not near as good as the old red asbestos one, but they have all gone...
PostPosted: Sat Jun 05, 2010 10:44 pm
how well matched is the thickness of the inlet manifold to the exhaust? I had trouble with the middle one leaking because the inlet manifold too thick and the step in the washers too thin
I did a little tune up on a mate's new motor for Hay, and spent the rest of the day getting the gearbox out of the subaru, what a pain in the ass - I love working on minis
PostPosted: Sat Jun 05, 2010 10:59 pm
Wheel rotation front to rear. My Dunlops are actually starting to show some signs of wear several years later!!!
PostPosted: Sun Jun 06, 2010 12:50 am
I put the side windows back on which made me decide to put the chrome trim back onto the front doors, just didn't look right without them. Tomorrow more interior work. Next week I have new brake components coming. Car should be driveable by the end of next week.
