It is currently Mon Aug 04, 2025 3:16 pm
 Post subject: Hairy underlay stuff
PostPosted: Fri Jun 04, 2010 6:28 pm
Some of the hairy underlay stuff under my rubber floor mats is rotten.
(Actually doesn't look so bad in that piccy)
What is the proper name for this stuff?
Could they thought of a better way to trap moisture and promote rust in the floor?
Is this stuff still available?
1970 Mini K
PostPosted: Sat Jun 05, 2010 7:53 am
It's Hessian
They used hessian underlay under almost all carpets then.
There is a foam alternative that most people use now, it still holds a bit of water doesn't rot.
Jacob
PostPosted: Sat Jun 05, 2010 11:36 am
Resident Haemorrhoid
you could try bellybutton lint as an alternative :wink:
mtsmini wrote:
Tombo wrote:
PostPosted: Sat Jun 05, 2010 3:52 pm
I run my carpets without underlay, I can't hear road noise with the Dellorto carb anyway. :lol:
PostPosted: Sat Jun 05, 2010 5:08 pm
Cheers. Might try nothing (or belly button lint) for a while and then see if I can clean up the enough of the original to get by - some of it is fairly yukko though.
1970 Mini K
PostPosted: Sat Jun 05, 2010 5:16 pm
I leave mine out too and when I do a resto I am going to set the carpets up so they can be easily taken out to inspect underneath. Maybe with velcro. I will fix up all the leaks too to stop any rust coming back I hope!
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Sat Jun 05, 2010 6:17 pm
I double up on the carpet. I fit an old carpet on the bottom furry side down and then fit the other carpet the right way up. I also trim the bottom one a bit around all the edges to fit better.
PostPosted: Sat Jun 05, 2010 10:09 pm
You can also use the more modern stuff that can be purchased through Knox Carpets or Tru-fit.
If you use nothing you will find overtime that you can see the floor pressing shape through the carpet.
PostPosted: Sat Jun 05, 2010 10:15 pm
what can we use as an alternative as I'm about to do this also
PostPosted: Sun Jun 06, 2010 9:46 pm
why not just settle for a pair of ear plugs, if your deaf in one ear they'll last you twice as long :D
PostPosted: Sun Jun 06, 2010 10:25 pm
rubber matting from clark rubber. works really well. you can get stuff with a grip pattern on both sides. insulating, sound deadening and water proof.
1962 850,Frog
