After vowing not to get certain things done in the Netherlands because they cannot do anything right, I ignored my own advice and was convinced that a particular machine shop was able to assess if they could salvage my crank after the thrust bearings damaged it.
I was particularly worried about a deep hole that looked as if it would not be able to be ground out, see pic below.
I was assured it was no problem, and in fact had already cleaned up perfectly. I gave them the specs of the thrust clearance to aim for and they said that they could do it.
I needed a new crank damper and had them change the ring gear on the flywheel. This meant re-balancing the rotating assembly.
All this costs a shipload of dough over here.
Received the engine back last week with the crank, pistons and rods all assembled and torqued up plus the flywheel and damper attached. Of course I dissasembled to make sure everything was good as well as to give it all a final clean and make sure all the little bits of metal are gone.
This is what I found on the crank thrust face.
The damn hole is still there. I can feel a sharp edge with my finger. I think this will tear the thrust washer to shreds taking me back to step one.
Should I stick it in and take the chance? Anyone had a thrust face in not perfect condition last for a reasonable timeframe?
Can I linish this to be smooth but still a divet and have it survive?
michael
66 Mini Minor sponsored by
http://www.lifeonthehedge.com.au/ The Dog Harness Specialists
It was a pleasure ausmini. I'll miss all you misfits and reprobates
