Thorlek wrote:
more on topic tho.... if you blocked up the undercarriage and made it quite smooth is should make a fairly decent improvement to the aerodynamics.
Yeah that's part of the idea aswell.
maybe chopping/ reshaping roof, Mini Monaco style would help aerodynamics as well... not really a cheap option tho
If I was going to chop a roof it would be on a van in the Monaco style, 2 inches at the front (in total height but rack the windscreen back instead of cutting the A pillars), and cut the rear down 4 inches or more.
dodge wrote:
go on a diet ,
u can acid dip the body till its .6mm thick
Go on a diet
I already weigh 55 odd kilograms
I'd prefer not to acid dip for cost reasons and also strength issues
EAB I reckon that may also help slightly. It's putting more air up in front of the windscreen but like the theory it also creates an extra updraft so it may help in that area...
