It is currently Wed Jul 23, 2025 11:41 am
Post new topic Reply to topic  [ 53 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: rebuilding gearbox
PostPosted: Mon Mar 28, 2005 4:25 pm
just want to not what parts i will need to replace when rebuilding my gearbox.
a list would be nice plz.
PostPosted: Mon Mar 28, 2005 4:47 pm
Im not an expert but....the things that are worne or broken :P
Topher
~`Topher`~
15years old...but no mini yet :(
PostPosted: Mon Mar 28, 2005 5:48 pm
Generally
The layshaft
The double row main
and various other bearings.
YOu may also need to replace gears if there are worn.
Aaron
PostPosted: Mon Mar 28, 2005 5:49 pm
Syncro's
PostPosted: Mon Mar 28, 2005 5:53 pm
Yep, i forgot that one.... just got back from 9 hours in a car, not thinking straight yet
 Post subject: Forks!
PostPosted: Mon Mar 28, 2005 6:06 pm
check selector forks....
also, a common one...check condition of splines on transfer linkages and how well thay are clamped.
hows the diff?? hows the diff bearings??
PostPosted: Mon Mar 28, 2005 7:17 pm
diff is ok crownwheel is stuffed. any idea on prices
PostPosted: Mon Mar 28, 2005 7:28 pm
Fit a competition diff pin and 2 new planet gears.. they don't last forever!
:idea: Rock the output shafts to and for to check wear, while looking at the pin & gears. You can do this looking into top of box while diff is in it. :wink:
PostPosted: Mon Mar 28, 2005 7:31 pm
do u think i will be able to rebuild it for less that 400 bucks. i am gettin help for my mate dad on the rebuild so labour is not a cost just parts. As i am tryin to keep sum money in the bank for when Kev's got time to make up my rockers.
PostPosted: Mon Mar 28, 2005 7:40 pm
Depends what the bearings etc are like. When I pulled mine out to change the cam, the gearbox cost me nearly $600 in parts alone. And I didn't need to do the 4 synchros, which are over $30 each now! :?
Whatever, change all the needle bearings and check the layshaft, which is invariably stuffed.
PostPosted: Mon Mar 28, 2005 8:05 pm
As I'm finding out at the moment some of those parts are not cheap.
The double row main bearing was over $100,the lay shaft bearings will be around $50 and I know that I need at least one new diff bearing which I haven't priced yet.
A new selector fork is horrendously expensive and for such a small item a diff competition pin isn't cheap.
If you have the gearbox apart you might as well put a central oil pickup in ,another $80-$90.
At least I had a good layshaft,gears and syncros.Still its a good learning experience and its one thing at a time at the moment.
PostPosted: Mon Mar 28, 2005 8:23 pm
i was gunna put a centrol oil pickup in i hope the rest isn't to bad. but i wanna do it right the first time so i don't have to do it again for aleast a year or 2
PostPosted: Mon Mar 28, 2005 8:41 pm
Look close at the layshaft, inside the 1st gear end of cluster gear. If it's wearing thru the hardening, bin it. :wink:
PostPosted: Mon Mar 28, 2005 8:46 pm
how much does a laygear cost approx cause i'm only a first year apprentice mechanic and i have 2 broken mini's on my hands. but i took the 1100 auto out of the Morris today and after a clean and a few bits and pieces that should be fixed so then i will have sumthin to drive to work in after i drop it in the white mini
PostPosted: Mon Mar 28, 2005 8:48 pm
It's not the laygear you replace, but the layshaft.
They are $50 -$90 depending where made and material spec. Dearer is better. :wink:
