It is currently Fri Jul 18, 2025 12:49 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Hydro pump help.
PostPosted: Thu Jun 17, 2010 6:02 pm
I have one of these,
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWAX:IT
Just wondering if anyone had any idea how the hoses inside the unit are directed.
If only I took note before I pulled it apart. :roll:
Image Image
PostPosted: Thu Jun 17, 2010 6:10 pm
What do you need to know. I have photos of everything.
PostPosted: Thu Jun 17, 2010 6:11 pm
i've got an unmolested one in the shed you can have a look at next time you down this way.
i'll try to take a picture on the weekend.
Mitch
PostPosted: Thu Jun 17, 2010 6:35 pm
Thanks Mitch, I could be down south this weekend. PM your number if you like and I may drop in.
Mr Morris, a while ago I cut away the hoses from the fittings because everything was seized and I've forgotten where they go. I've never used it so I'm not familiar with it's operation, so I'm seeking some sort of diagram showing where the hoses connect.
Cheers.
Image Image
PostPosted: Thu Jun 17, 2010 7:11 pm
Cheers.
:shock:
I could try to draw a diagram it may take a bit.
I hope you kept an eye on the little valve bits as you pulled it apart?
PostPosted: Thu Jun 17, 2010 7:17 pm
Here is a couple of shots to give a bit of a clue...
PostPosted: Thu Jun 17, 2010 7:43 pm
Thanks Morris, the pics give me a fair idea of what's going on.
How long should the hoses be that go to the car?
Image Image
PostPosted: Thu Jun 17, 2010 7:53 pm
The hoses that go to the car do not need to be that long on a Mini but they need to be a bit longer on other cars like the 1100. 2 or 3 metres should do it.
It is very high pressure hose. I think it is similar to Parker Parflex but I am not 100% sure.
PostPosted: Thu Jun 17, 2010 8:03 pm
Just measured my one and the hoses are 2 meters give or take a little.
Is yours a Churchill or an Austaloy pump?
PostPosted: Thu Jun 17, 2010 8:17 pm
It's an Austaloy pump.
I got it given to me when I retrieved a dead clubman out of a farmers dam. :D
Image Image
PostPosted: Thu Jun 17, 2010 8:24 pm
Good work! It should have the same fittings as mine.
I did a little cheat on my one, on the back panel where there are two holes for the hoses to come out, I filed the holes so that the nut on the end of the hose would fit through the panel. A new grommet hides the hexagonal hole.
The vacuum pump need to be filled with oil through the hole in the top of the pump (then the pump is at the top of the stroke) the oil is what makes the pump seal.
PostPosted: Fri Jun 18, 2010 6:37 am
A few years ago, I had some instruction plates remade for the top of Churchill pumps. I am thinking of getting more done, anyone interested?
Regards
Al
PostPosted: Fri Jun 18, 2010 4:50 pm
Regards
Al
Yes, I am very interested.
I don't know if the Austaloy pump has the same instruction plate as the Churchill pump. (help 850man do you know the answer?)
But I would be willing to take one as my pump does not have one at all. :D
PostPosted: Fri Jun 18, 2010 6:42 pm
Has anyone considered putting swivel fittings on the end of the hoses? I find on some cars (mini's aren't to bad) that screwing the connector onto the car is quite awkward when the hose is fighting you. I can't remember the name of it now, but some austin, maybe a maxi? connects through a 2x4 inch hole in the boot. PITA.
I'll have a look at the hydro pumps we have at work next week as they are 2 different designs and i will compare the instruction plates and see if they have a brand name.
PostPosted: Fri Jun 18, 2010 8:10 pm
Regards
Al
I'd be keen on buying one too
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
