It is currently Fri Aug 01, 2025 11:36 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 157, 158, 159, 160, 161, 162, 163 ... 568  Next
PostPosted: Wed Jun 16, 2010 6:02 pm
1. Evacuated and pumped up both sides of my hydro suspension. Thanks Mick for your help and advice. Cars a lot better, (300PSI, 300mm front wheel center to arch), but I think either I need washers under the front knuckles and/or new/shorter rear helper springs to lower the back a bit.
2. Fitted new speedo to center instrument binnacle and did some rewiring and patching.
Jim
PostPosted: Thu Jun 17, 2010 7:08 pm
Fitted new Alternator now battery charges nicely. Founds she runs much better with a decent amount of volts coursing through her wires. :)
PostPosted: Thu Jun 17, 2010 8:22 pm
After yesterdays hydro pump up, I let it down a bit to ~260PSI and 280mm wheel center to arch height. Mick pointed out that 300PSI was on the high side, and that maybe I was being slightly paranoid about the ride height being high enough for the forthcoming RWC. Thanks again Mick.
PostPosted: Thu Jun 17, 2010 10:10 pm
Jim
Dont forget that mini's are meant to sit slightly rake, as far as i know at least..
You're so square
Baby I don't care
PostPosted: Thu Jun 17, 2010 10:39 pm
I fitted 2x new Hoosier-daddy speedway Tyres to my buggy :-)
PostPosted: Thu Jun 17, 2010 10:41 pm
I finished swapping radiator etc from the 1360 onto the 1412 stroker. It's going in tomorrow! :P
PostPosted: Fri Jun 18, 2010 2:39 am
I picked up my plastic blasted 850 doors & went and purchased some etch primer. Hopfully I will get to paint them today. :D
Have a Nice Day.
PostPosted: Fri Jun 18, 2010 7:05 pm
replaced some rusted bits in the boot, Morris sure didn't want that battery box to come out, dozens of spot-welds and brazed corners
PostPosted: Fri Jun 18, 2010 7:07 pm
Blacked the tires and i blacked them good.
Couldn't wash the car though, all out of wash.
You're so square
Baby I don't care
 Post subject: Off the Spit!
PostPosted: Fri Jun 18, 2010 7:45 pm
Took the blue thing off the spit , bolted on wheels and have put it into work position under landing and parked the gold thing now that it is near finished and on the road, in its new home( the garage)
PostPosted: Sun Jun 20, 2010 5:05 pm
Sold the Woody
 Post subject: Re: Off the Spit!
PostPosted: Sun Jun 20, 2010 5:15 pm
i'm lovin that colour on the 'gold thing' :lol: ! Very nice!
i barely even looked at my mini today :( (or the last 2 weeks if i'm reaaaaally honest!)!
Cheers, Kim :-)
**purple '68 deluxe!**
***FINALLY wearing number plates----yeaaaaaah baby! ***
AWOODY wrote:
Sold the Woody
:shock:
You're so square
Baby I don't care
PostPosted: Sun Jun 20, 2010 5:17 pm
I picked up another 79 mini yesterday.........Today I checked the brakes n hav just been finding parts to build it up.......doing some welding on the rust.......its only done 25000kms but doesnt hav the origional speedo with it.....grrrrrr
It has a big rust hole in the boot ad the front seam covers are shot......some small rust along the gutter in the front but its very clean.......just gota put an engine in it and a steering rack.......c how we go.
61 van
63 countryman
63 saloon
67 auto
73 auto clubman
75 1000cc clubman
77 sccr 998 clubman
NZ 79 1275gt clubman estate
79 LE
80 meanee
Racecar
Fiat 500
PostPosted: Sun Jun 20, 2010 6:07 pm
Gave it a wash and headed out to Hunter Valley Gardens to check out the cars at the mid winter wander.
