It is currently Sat Aug 23, 2025 5:18 am
PostPosted: Sat Jun 19, 2010 5:14 pm
Well, I need to replace the top bush in the steering column.
How do I remove the brass ring for the horn?
Any tips?
Can I do it in the car?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sat Jun 19, 2010 7:15 pm
Sorry, don't know.
But good to see you're not doing what I did. Thinking the ring was part of the horrible aftermarket boss on the mysterious column I had lying in the shed, I cut it off with a Dremel. Very effective method, but of course now that I know it's an essential part, difficult to refit. :roll: Turns out they're no longer available.
Maybe use a bearing puller?
PostPosted: Sat Jun 19, 2010 7:25 pm
Mods rock!
I've never had to do it on an early car, but I do note that originally they were fitted with a felt bush, so it may not come off to allow for replacement bushes of the newer type. The old felt bush wraped around.
PostPosted: Sat Jun 19, 2010 7:34 pm
The fingers on the top end of the slip ring grab into a shallow groove in the plastic insulator underneath, but apart from it should just pull off. The fact that four of the fingers on mine were broken off even before I got to it leads me to believe it's probably a very tight fit.
PostPosted: Sat Jun 19, 2010 8:03 pm
So.....
Do I just force it off? Won't this damage the wire for the horn?
Can it be put back on easily?
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Sat Jun 19, 2010 8:11 pm
No, that shouldn't damage it. The wire ends in a brass terminal on a spring, which contacts the slip ring - it's not permanently attached.
PostPosted: Sat Jun 19, 2010 8:18 pm
I would think that it would be as easy or difficult to get it back on as it is to get it off. Probably a bit easier, since the springy finger bits won't be working against you. I can't really say for certain, since mine's in two pieces, and will be glued back on if I can't think of an alternative.
PostPosted: Sat Jun 19, 2010 8:26 pm
Mods rock!
ryan wrote:
So.....
If it jams, force it.
If it breaks, it needed replacing anyway :mrgreen:
PostPosted: Sat Jun 19, 2010 8:30 pm
An excellent motto. :D
But in this case, it'll be difficult to replace - you can't buy the slip rings new.
PostPosted: Sat Jun 19, 2010 9:49 pm
After posting this I went out into the garage and I actually realised that I did this same job 6 years ago and I kept the brass ring and the plastic bits, so if it breaks I have spares :) hows that for a quality memory :oops:
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Sat Jun 19, 2010 11:41 pm
Haha, memories aren't designed to last six years. If you get as much mileage out of one as a bar of soap you're doing well I reckon.
If nothing's busted once you've fitted your new bush and you feel like selling your spare slip ring bits, send me a PM.
PostPosted: Wed Jul 07, 2010 9:09 pm
So, I did this yesterday. It was a very easy job. I did it with the column still in the car.
The brass ring, with a bit of twisting and a good tight grip slides off, and then I just had to fish the old bush out (this was a little tricky without removing the inner column. Then just reassembled. The new bush took up all the play. Happy Days!!!
Simms PM Sent.
Ryan Filippi
Minis In The Gong
[email protected]
Users browsing this forum: No registered users and 238 guests
