It is currently Thu Aug 07, 2025 12:56 am
PostPosted: Sat Jun 19, 2010 7:39 pm
Thanks for the info guys. :D
PostPosted: Sun Jun 20, 2010 10:24 am
Hi Kev
found the bloody thing, hidden in my special parts box LOL
It has no makings on it other than a large J and smiths industries limited UK
I think I got it from Howard Instruments in Melbourne
Kiwiinwgtn
PPS I will go down this afternoon and see my neighbour who has Jags for africa and see if it looks the same
PostPosted: Fri Jun 25, 2010 4:19 pm
OK I have officially given up on fitting the HS6, GR7" manifold and Ramflo filter in my 1970 roundy.
Even with a 90° angle box on the speedo, the Ramflo will not fit in there. I would have to move the instrument panel into the cabin.
So, the carb, manifold and filter will be for sale soon.
Perfect for one of those later model flat chested Minis. :P
The 45 Dellorto is going back in, but with 36mm chokes in it instead of 38s. This should pull the torque figure up a bit.
Last edited by drmini in aust on Fri Jun 25, 2010 10:28 pm, edited 1 time in total.
PostPosted: Fri Jun 25, 2010 4:55 pm
Flat chested? - they've got an extra 6 inches on you pal!! (or is it 4"? I forget) :lol:
PostPosted: Fri Jun 25, 2010 5:41 pm
Well I could have said `English Ford fronted', but people might get upset at the truth. :mrgreen:
PostPosted: Fri Jun 25, 2010 9:23 pm
ausmini mod
ausmini mod
Cmon Kev, not like you to give up that easy.
Chong bought one too... does yours have the box cut out for the carb or not - cant remember for the life of me.
Graham angles the manifolds, has yours been angled?
Pete
PostPosted: Fri Jun 25, 2010 9:26 pm
I wouldnt mind a clubman with an escort rs2000 rear end.
Simplify and add lightness
PostPosted: Fri Jun 25, 2010 10:15 pm
Pete
Chong tried one, his didn't fit either. Even with his Weber box in. So he's still running the Dellorto.
No, mine has no Weber box but I've cut the hole away as much as I'm going to.
Carby is not the problem. The filter just about hits the speedo. And they are shorter than all the others.
Yes the manifold is angled up, but the problem is the overall length. Yes it will fit with NO filter, but I'm not running a road motor without one.
The only roundy I've seen where it all fitted (with a filter) was Greig's GF's MiniMatic, but Matic motors are mounted more forward in the subframe than manuals, by 20mm or so.
PostPosted: Sat Jun 26, 2010 1:37 am
Is it the cable or the speedo that is the problem?
Can you make a spacer to shift the whole speedo inside the car by 20-30mm and sneak the cable under/over/around the filter?
I have been thinking that a spacer around the speedo housing where it mounts to the firewall would do the trick. You could also do this and run the cable sideways out of the speedo housing and through a new hole in the firewall if necessary.
michael
PostPosted: Sat Jun 26, 2010 2:56 am
What about a smal 'plenum' type of air box and a remote airfilter? :) Sort of lwhat the Bertone Innocentis got?
http://666kb.com/i/b18kh3usuoogqmhp8.jpg
http://666kb.com/i/b18khnzyw3py64k64.jpg
Of course a little bit more sophisticated :)
PostPosted: Sat Jun 26, 2010 3:15 am
How about a short ram tube and a "sock" type air filter. Thats what I did with the last long manifold & weber I fitted to a mini. The back of the speedo gets a bit oilly from the sock but it all gets squeezed in there ok.
Have a Nice Day.
PostPosted: Sat Jun 26, 2010 3:43 am
Milatsmadmini
Im gonna +1 this one Kev, a motorbike sock with a small spring (which you could easily cut down if need be) would be a suitable option and make all the young hip kids go, ga ga oooooooooo...... :P (cause you would be even cooler than you are now... gets it?)
PostPosted: Sat Jun 26, 2010 9:09 am
michael
They used to sell an oval standoff for the binnacle years ago. But IMO it just looks wrong in a road car.
If the cable is off it will fit. OK on an Nb racer.. not for the road.
If the cable is on, the filter plate hits the cable. It would have to go through the damn filter.
If a 90° box is on the speedo the filter foam cover will hit that.
Nope it ain't broke with the 45 Dellorto so I'll use that instead. HP was the same @6500, and I think midrange was only down because the thing had 38mm chokes in (the head isn't ported real big, the one on the 1360 is better)- it now has 36s.
[edit] it's in now, not fully tuned the jetting yet but it's got good midrange torque with the Dellorto.
PostPosted: Sat Jun 26, 2010 6:37 pm
Not such a bad idea that. Don't know how that will affect the flow though :lol:
Mine has 36mm chokes and is excellent for midrange torque.
PostPosted: Sat Jun 26, 2010 7:03 pm
I found 38s better for HP in the 1360, but it's a Dellorto not a Weber. They seem to like big chokes more than Webers do.
