It is currently Tue Aug 19, 2025 5:52 pm
 Post subject: Rod Change Linkage Play
PostPosted: Sun Jun 20, 2010 11:16 pm
Uh Oh Spaghetti O.... Not sure why I never noticed this before?? Perhaps it was one of those "gunna" jobs...?? Strange that it still shifts gears fine?
http://www.youtube.com/watch?v=bQ2u0sMPqXU
PostPosted: Mon Jun 21, 2010 9:36 am
the slop doesn't look too excessive - probably quite normal. You could try a new sleeve and roll pins maybe.
PostPosted: Mon Jun 21, 2010 9:44 am
Should there be any play there at all? I would of thought it should be pretty tight?
PostPosted: Mon Jun 21, 2010 6:48 pm
As long as the pins are tight (not any chance of them falling out) and there is no 'rotational play' (not sure of the correct engineering term) then I can't see a huge problem with it.
Over time the pins will wear into the yoke and make the change sloppy but then it'll just be like every other rod change :lol: At that point I usually grab a nice sharp drill bit and drill them out to the next size.
PostPosted: Tue Jun 22, 2010 12:27 am
quite normal, i have seen some new from the factory with more play ....
Rover 214 atm ....
PostPosted: Tue Jun 22, 2010 12:38 am
Yes, looks normal to me too :) Though jubilee clips can help (& also prevent the pin from falling out). Of course positioned in a way they don't foul the gearbox casing ;)
PostPosted: Tue Jun 22, 2010 8:14 pm
That's WAY better than my moke! Need long arms to get first and fourth with tight seatbelt!
PostPosted: Tue Jun 22, 2010 11:11 pm
Hmmm, ok then...! I would of fitted new roll pins when i fitted it up all up. I just wouldnt of expected the shaft to have that much movement inside the sleeve and for the sleeve to have that much movement on the gearbox?
PostPosted: Wed Jun 23, 2010 1:06 pm
NAV-MAN
That movement is normal.
If you want to remove that play in it have another sleeve custom made up that is a tight fit over each shaft, Or have it bored out slightly and add an oil resistant rubber or nolothane sleeve inserted so its a tight fit.
PostPosted: Wed Jun 23, 2010 3:29 pm
yep, all pretty normal there & in fact quite good compared to some
MY advise to every one who uses rod change gearshift tho, is to use some "Tie-wire" through the roll pins as a "Just-in-case"
Users browsing this forum: Bing [Bot], Sreedon and 76 guests
