It is currently Wed Aug 20, 2025 2:19 am
 Post subject: Cam Bearing Press?
PostPosted: Mon Jun 21, 2010 10:00 am
Does anyone have photos or drawings of a cam bearing press?
PostPosted: Mon Jun 21, 2010 6:19 pm
Is this what you are looking for?
Go to "How To", then "Install Cam Bearings"
http://www.aptfast.com/
Steve
PostPosted: Mon Jun 21, 2010 9:50 pm
thanks for that link... Having a lathe and all I can make that
blokeinamoke wrote:
PostPosted: Mon Jun 21, 2010 10:09 pm
too easy !
PostPosted: Mon Jun 21, 2010 10:37 pm
Make sure when you put the bearings in you line up the holes with the oil galleries :D
PostPosted: Tue Jun 22, 2010 10:00 am
Thanks, That's just what I wanted.
PostPosted: Tue Jun 22, 2010 5:37 pm
And be careful with the front one- check the old bearing's various hole positions before you push it out.
PostPosted: Tue Jun 22, 2010 9:05 pm
got pics showing a correct one?
PostPosted: Tue Jun 22, 2010 10:10 pm
Sorry no I don't, nor do I have a block (with the bearing in) handy right now.
But if you get it wrong (backwards?) you can get full pressure feed to the rocker gear, not the correct intermittent pulses from the axial groove on the cam journal.
PostPosted: Tue Jun 22, 2010 10:59 pm
Been there! Local machine shop put the bearing in the wrong way, it was fine until you held constant high revs for a length of time, then I had oil comming out the rocker cover and filling the catch tank.
Users browsing this forum: No registered users and 382 guests
