It is currently Fri Aug 22, 2025 6:22 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Mon Jun 21, 2010 8:29 pm
Thanks Steve!!!
Are the studs the same length or do they have to be changed also?
PostPosted: Mon Jun 21, 2010 9:13 pm
Studs are shorter, but can use bolts too.
Steve
PostPosted: Mon Jun 21, 2010 9:34 pm
So what are people using in racecars then? I used to use BP Corse 50C? What is the best?
PostPosted: Mon Jun 21, 2010 10:43 pm
so guys with the new spin on heads having a different thread, does this mean the standard Z418 ryco filter will not fit?
i just ordered one for my engine.
Jason
PostPosted: Tue Jun 22, 2010 12:39 am
Supercharged
Castrol EDGE Sport 25W-50 is the ultimate product dedicated to satisfying modified engines, push-rod technology, street machines and the big bore competition engines.
i use castrol edge sport 5w30 in my turbocharged colt ralliart.
and on good advice i switched from 25w50 to the 10w60 in my supercharged mini.
i've tried KMX but i wont be buying it again, i can usually get valvoline or some other brand name oil for less money. Sorry but i'm not a fan of home brand stuff. But i did give it a go.
also i find it puzzling when people say penrite oil doesnt give as much oil pressure at higher temperatures, considering it nearly always has a higher viscosity rating than the equivalent oils from other brands. 20w60 instead of 20w50 etc.
Users browsing this forum: No registered users and 295 guests
