It is currently Tue Aug 19, 2025 11:02 pm
PostPosted: Tue Jun 22, 2010 9:53 pm
Hi all
Just refitting my drive yokes to the diff and want to double check on the correct way to fit the two collets.
They have a lip or ledge on one side and i assume this fits inwards towards the diff but would like to double check.
Also the rubber seal that then fits on the bolt has a protruding lip on one side, does this point in to the diff or out to the washer? there doesnt seem to be a lot of room for this rubber seal to squash into? Is that normal
Also couldnt find a tension to do centre bolt up to, is there one specified
All replies appreciated
Thanks
PostPosted: Tue Jun 22, 2010 10:01 pm
The chamfer on the collets goes towards the diff.
The rubber seal bit goes towards the diff. But IMO these seals now are a bit too thick, they can split outwards past the washer when assembled. There is only 3.6mm of space in there for them when assembled.
Note that there should be a spring washer between bolt and flat washer- if you don't use it they will definitely split.
The other problem with the latest rubbers is they are just natural rubber, and the oil rots them... what were they thinking...:twisted:
I made 2 new flat ones for mine out of Notathane front tie bar rubbers- I sliced them off with a Stanley knife and sanded them to 4.75mm thick. Outside diameter is correct.
PostPosted: Wed Jun 23, 2010 7:14 am
Mods rock!
guna mk1 wrote:
Hi all
Thanks
70 ft/lbs
Users browsing this forum: Bing [Bot] and 76 guests
