It is currently Mon Aug 18, 2025 11:13 am
 Post subject: Front pulley seals
PostPosted: Wed Jun 23, 2010 6:51 pm
Is there a difference in front pully seals between pulley types. Eg harmonick pulley, S pulley
I have the factory churchill seal installer and its too small.
Thanks
Kiwiinwgtn
PostPosted: Wed Jun 23, 2010 6:57 pm
Mods rock!
Diameter wise they were all the same on A Series fitted to Minis.
PostPosted: Wed Jun 23, 2010 7:29 pm
thanks, i thought as much.
What about timing covers, eg where they mount on to the back plate also are all back plates and cover mounting postions the same
TA
Kiwiinwgtn
PostPosted: Wed Jun 23, 2010 7:35 pm
Mods rock!
TA
Kiwiinwgtn
Positions were all the same, and the holes should all be the same (as all the 5/16" UNF ones actually go through the plate and in to the block), however note that there was a later timing chain cover around the time of the A+ to include the tensioner, while the holes were in the same places on the engine plate, there was an additional hole in these later ones. They are interchangable, just need to dril a hole in the early engine plate when used with the later cover.
PostPosted: Wed Jun 23, 2010 8:38 pm
Thanks for your help.
I went out to the garage and had a closer look I can see how the tool works, it centres the seal via the out side of the cover not the shaft,
I tried it once and I could not get things to line up, just tryed on my set up motor and it aligns perfectly so will see how I go when i re install the front cover hopefully no more leaks from the front pulley
Have tools got too use them
Kiwiinwgtn :lol:
Users browsing this forum: No registered users and 114 guests
