It is currently Sat Aug 16, 2025 12:26 am
 Post subject: heater tap stud
PostPosted: Wed Jun 23, 2010 7:02 pm
Managed to break a heater tap stud in the head of a 1275 head, pretty well flush with the head surface
Any advice on removal, easy outs?, drill and re-tap?
PostPosted: Wed Jun 23, 2010 7:29 pm
Mods rock!
3 Hail Merrys first.
Use a pin or flat face puch and gently tap a few times to try to get a bit of a flat surface on the stud first. Lightly centre punch and check with a gasket, if OK then punch again, drill and tap (1/4" UNF).
Don't bother with easy outs, it'll break too only making it harder to remove.
PostPosted: Wed Jun 23, 2010 7:37 pm
What he said ^^^
When drilling, do it in a bench drill, NOT by hand. I have a head here that was drilled out by hand (not by me), it ran off centre and they drilled through the side of the head!! :shock: But I fixed it. :P
PostPosted: Thu Jun 24, 2010 7:43 pm
thanks for that
