Phat Kat wrote:
haha,, well I remember 2 of them
I nearly said Chromium, glad I didn't
It looks like most tool steels.
Got to say though.... WHY? wouldn't it be cheaper to do them in S/S than exotic steels? S/S might be a bitch to machine, but it would do teh job more than fine and its got to be cheaper?
ah,, who am I to question these things
SS is pretty soft, usually. And does not wear well. Stellite is a hardfacing alloy, it's hard stuff, and some grades are used because they have a low coefficient of friction against steel. For example you don't usually make complete valves out of it- just use it on the wear faces (like the valve face and end of the stem).
[edit]
example: Stellite 1 (which we used at work)
% composition:
Co: bal
Ni: max 3
Fe: max 2.5
Al:
B:
C: 2,45
Cr:31
Mn:1
Mo:
P:
S:
Si: 1
Ti:
W:13
Specifications:
Stellite 1 is a hardfacing alloy possessing high abrasion and corrosion resistance for applications such as pump sleeves and rotary seal rings, wear pads, bearing sleeves and centreless grinder work-rests. Retains hardness at temperatures in excess of 760°C (1400°F). Also available as thermal spray powder, JK 7201.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
