It is currently Wed Jul 23, 2025 9:31 am
 Post subject: 7.5" Discs
PostPosted: Sun Jun 27, 2010 10:30 am
Have a set of 7.5" discs to go on the Clubby, also have a booster (VH44?). What master cylinder do i need, will the original drum one be ok or do i need to change it. Booster or no booster? Never ran one on my old rally cars, but never got around to fitting one to see the difference.
General consensus?
PeterN
3x Leylands
1x 850
Mildura,
Victoria.
PostPosted: Sun Jun 27, 2010 10:39 am
std master is fine,,, i don`t use boosters & nor do any of my mates now days,,, they don`t make the brakes work any better,,, it`s more a "feel" thing as the booster only relieves peddle pressure
you may need to use the "S" rear brake limit valve tho,,, depending on your rear wheel cyl sizes & the condition of the rear brakes,,, if everything was std mini issue in the rear then "Usually" the rear brakes will lock up under hard braking conditions , or in the wet/dirt when "S" discs are fitted to the front
PostPosted: Sun Jun 27, 2010 10:56 am
If you are tempted to keep the old rear wheel cylinders with discs fitted, I'd go try it out on a dirt road somewhere to be sure, not on the F3 at 110K in an emergency stop, like I did.. oops, plenty sideways! :shock:
PostPosted: Sun Jun 27, 2010 10:00 pm
Just standard rear drums, can you mod the original rear valve to adjustable, the car will be seeing a lot of dirt competition.
PeterN
3x Leylands
1x 850
Mildura,
Victoria.
PostPosted: Mon Jun 28, 2010 6:46 pm
yes,,, but best to "try" & find a seal kit for it before you do this, but anyways--->
rip it apart, drill a hole into the back of it,,, tap a thread into it,,, shorten the spring a coil or 2,,, fit the new seal kit ,,, but before setting the spring & piston assy back in it`s place, fit a one-cent piece (or flat washer of similar size) for your new adjusting bolt to work against it,,, then fit the guts back in,,, wind your new bolt in with a lock nut added to it (i usually weld a lever onto both the bolt & another lever to the lock nut so you now have 2 separate handles/levers ,,, one to unlock the lock nut & the other to adjust the bolt) then i normally fit an o-ring on in-front of the lock nut (between the lock-nut & the body of the valve) as a "Just in case" it leaks type of thing
Job done & no you can start playing with your adjustment
softer spring equals less pressure to the rear brakes
stiffer spring means more pressure to the rear brakes
