It is currently Sat Aug 02, 2025 1:42 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 160, 161, 162, 163, 164, 165, 166 ... 568  Next
PostPosted: Mon Jun 28, 2010 10:56 pm
jb007 wrote:
simon k wrote:
jb007 wrote:
Return to RWC tester and they didn't even check that all faults had been fixed... go figure!
that's normal.... why would you go back and say you'd fixed them if you hadn't!
jb007 wrote:
To top things off Vic Roads want to inspect car (before issuing plates) because the 5 digit chassis number (26129) is also recorded against two other non-mini cars. They are going to charge me $38.xx extra for this privilege!! They also say that they might have to issue a new chassis number. I bet you my car which is 42 years old, had the number before the others and why wasn't it an issue 18 months ago when It was previously registered in Victoria?:roll: :shock:
bugger - not sure if your car has a number on the radiator shroud or not, but that's the one to use...
Not sure, I'll check tomorrow morning. Which one is the chassis no, radiator shroud or the one under the plate near clutch M/C ?
If the car is a 68 the correct number is the one on the firewall near the master cyl. (which should match the ID plate just above it).
With later Minis the correct No is on the rad cowl so it sometimes causes confusion with the inspectors.
My 4 digit no. also matched 2 other (old) cars and a boat trailer.
PostPosted: Tue Jun 29, 2010 12:46 am
Pulled the head off because the car did some serious smoking after startup this afternoon. Found some beautifully glazed looking bores.... Can't wait to pull the engine out to rebuild it again.. Guess I stuffed something up during the run in, or didn't hold my tongue right. Oh well live and learn I guess....
Double post.. Oopsies
PostPosted: Tue Jun 29, 2010 12:51 am
Milatsmadmini
:cry:
damn...
PostPosted: Tue Jun 29, 2010 5:55 am
been lapping the flywheel onto the crankshaft
PostPosted: Tue Jun 29, 2010 5:40 pm
Yes I agree, the number under the ID plate is the one to use. Don't let them issue a new number, try to get them to use the prefix off the plate as well as the number. (YMA2S2 + 12345 if it is a Deluxe)
PostPosted: Tue Jun 29, 2010 6:02 pm
when I registered my '66 panel van I used the numbers off the radiator shroud, MV04 464 - I still remember it 6 years later :?
they usually won't (shouldn't) let you combine the number by taking one bit from the plate and one from a stamping - that's why I use the radiator shroud number if it has one, it'll be the unique one.
The numbers on the ID plate are basically irrelevant, as is the body number off the firewall
PostPosted: Tue Jun 29, 2010 6:34 pm
mattsmadmini wrote:
damn...
Actually..... Just pushed it outside into the sunlight and the bores are looking pretty good, so I'm going to go with my first theory of oil draining down the valve stems (this also has the added benefit of me not having to crawl under the car to get that pin out of the rod change).
It was only smoking at first start up for the day but once it was warm (about 2 minutes) no smoke, even fanging around no smoke. I parked up for 30 minutes to visit my Mum got back in the car and drove off and no smoke.. Anyone got any thoughts?? I'm open for suggestions. :)
PostPosted: Tue Jun 29, 2010 7:23 pm
Thanks all. They did say that they might add a prefix, which I don't want, but if they insist then using YMA2S212345 would be better than them stamping a new number. I'll post tomorrow night the outcome. <sarcasm> Can't wait for the appointment! </sarcasm>
PostPosted: Tue Jun 29, 2010 7:49 pm
Step 1 remove ID plate
Step 2 stamp prefix above the car number
Step 3 get car inspected
Step 4 re-fit ID plate over the newly stamped prefix. :lol:
PostPosted: Tue Jun 29, 2010 7:54 pm
My luck would be they ask where the ID plate is! LOL :lol:
PostPosted: Tue Jun 29, 2010 7:56 pm
They wouldn't know! The ID plate has no legal requirement and it never did.
It was just there to make the dealers life easier.
PostPosted: Tue Jun 29, 2010 7:58 pm
I didn't know that! :)
PostPosted: Wed Jun 30, 2010 7:05 am
MiniKit wrote:
mattsmadmini wrote:
damn...
Sounds like valve stem seals. Did it smoke if you let it idle for a while then gave it a rev?
Dicko
PostPosted: Wed Jun 30, 2010 8:03 pm
Dicko
Has brand new valve stem seals, but only the cheap generic ones supplied by mini shops. I took off the valve springs this afternoon and found that the valves do have what I would consider too much wobble to them, some are nice and tight though and a couple of the valve stem seal are harder than the others more so on the looser valves..
Thanks for the suggestion Dicko. :wink:
Oh and yes it does if I let it idle and then give it a rev, but not as bad as when I first start it up from cold.. I figure the seals can only seal against so much..
