It is currently Tue Jul 29, 2025 3:00 pm
PostPosted: Thu Jul 01, 2010 10:49 pm
When it rains boxes,,, well it just pours boxes hey?
some of you may know that i`ve recently busted my kombi gearbox & i`m up for major chunks of money to repair the damn thing :-(
well as it turns out, i have had quite a few mini boxes booked in to repair & i`ve been sorting all sorts of things for the whole lot, Matching cases, decent gear assys, new bearings & shafts etc etc etc ,,, the usual but just plenty of it all etc etc etc,,,, & it seems to be they`re still comming thick & fast,,, so i ripped in yesterday & today & bundled 4x mini boxes together all nice & new,,,, & this arvo i set up to sort out another 4x of the damn things,,, then at 6-ocklock-ish tonight i get 2 more calls for another 2x of the dam things needing do-ing
crickey!!!!!!!!!!!!! I`m just about all Boxed out
can someone please tell the gear-box gods to back-off for a little while,,, Please???
It`s really only the cleaning part that sh!tes me right off :-( Damn things are always gungey & grotty & filthy disgusting to the "Nth" degree... if i could just employ a 25 year old blonde girl to clean all the cases for me it wouldn`t be so bad :-)
PostPosted: Fri Jul 02, 2010 12:04 am
don't you mean a redhead????
PostPosted: Fri Jul 02, 2010 12:08 am
i`m not racist , nor that fussy really :-)
PostPosted: Fri Jul 02, 2010 2:23 am
Why dont you stick them in a cold tank for a few hours, they come out very nice after a swim.
Have a Nice Day.
PostPosted: Fri Jul 02, 2010 6:54 am
Mods rock!
No, that's me with the Red Heads :wink:
Matt, get yourself an old but working dish washer (and no, I don't mean yr mum) :wink:
Yeah, cleaning is the worst of any of these jobs, but Gearboxes do always seem the worst of the worst......
That's not a bad effort there Matt........
PostPosted: Fri Jul 02, 2010 5:47 pm
just think of the funds they are providing to go surfing at Byron Again
PostPosted: Fri Jul 02, 2010 6:03 pm
can someone please tell the gear-box gods to back-off for a little while,,, if i could just employ a 25 year old blonde girl to clean all the cases for me it wouldn`t be so bad :-)
Well now that Ruby Rose has put the peroxide rinse through she qualifies as blonde , and apparently she's damn good at cleaning a box
PostPosted: Fri Jul 02, 2010 8:06 pm
Cant be that bad, Ive seen a camry box where I had to chip the sludge out.
Makes me consider using that nulon snake oil, Or dropping a bit of diesel in it before each change.
PostPosted: Fri Jul 02, 2010 9:31 pm
I'm amazed.. Whenever I take anything for repair, machining or service I make sure the parts are spotless. It's the decent thing to do. Isn't it?? :shock:
PostPosted: Fri Jul 02, 2010 9:47 pm
Certainly helps put the mechanic in a better mood.
PostPosted: Sat Jul 03, 2010 5:02 pm
At least its not diesel oil. I just last week pulled apart a little 3cyl turbo diesel stationary motor which was very poorly serviced. Ended up spinning the bearings in the rods.
PostPosted: Sat Jul 03, 2010 5:50 pm
Mien
The thing is, most of the ripoffs would charge you the same labour amount whether they cleaned it or your cleaned it.
PostPosted: Sat Jul 03, 2010 7:45 pm
See now that's the thing, but with me it's a matter of principle. The other thing is I trust very few people with doing mechanical work as I've been bitten before and don't enjoy being ripped off. If you go to someone long enough you build up a good relationship and if you look after them, then they look after you. I think anyone who has something to do with a business and Minis on this forum or in any business for that matter would agree with me on that. :wink:
PostPosted: Sat Jul 03, 2010 8:57 pm
Agree with you there mini kit. I always let people do as much or as little as they like. I prefer getting nice clean gearboxes to assemble, and I only charge per hour for my time so if I don't have to spend a couple of hours cleaning a gearbox I am happy. Also my customers are happy that they have contributed to their box rebuild and saved a bit of money as well.
I find its best to strip the box and then go through all of the components and show which parts are worn and why they should be replaced. A good way to operate I reckon.
Just my 2 bobs.
68 Mini
70 Moke
