It is currently Wed Jul 23, 2025 12:21 pm
PostPosted: Thu Jul 01, 2010 11:37 pm
Hi all,
How much cfm or litres per min flow do I need to run a radum blasting cabinet?
PostPosted: Fri Jul 02, 2010 7:08 am
Mods rock!
LOTS. Probably the minimum would be 22 cfm, but as always, the bigger the better...
PostPosted: Fri Jul 02, 2010 9:09 am
Agree with GTM. Be aware that some shops rely upon different pressures when they quote their "Free Air Delivery" figures. For some, their figures are based on 90psi, which gives a higher FAD figure than those who use the 100psi rating. So ask before you buy.
I pick up my 3 phase 7.5HP mother tomorrow morning :D . Looking forward to having that much "air" available :D
Steve
PostPosted: Fri Jul 02, 2010 10:19 pm
WATER TRAPS :!: get water traps. If you get moisture coming through your media blasting set up it can quickly clog up, very annoying :wink:
