It is currently Sat Jul 26, 2025 12:33 am
 Post subject: Im getting bored...
PostPosted: Thu Jul 01, 2010 11:06 pm
Im running out of things to do... So now it seems Im starting to pull my car apart again... Going to replace the door hinge gaskets. How much adjustment is there of the hinge on the body itself?? I dont mind aligning the door, but didnt really want to upset the hinges on the body..
Also Im not 100% happy with how the door frame sits on the drivers side, I think it needs to be bent inwards just a fraction... Anyone got any good ideas on how to go about doing that? Ive already wedged a piece of time in between the frame and the door to keep it ajar, then I backed off the bolts for the quarter glass and tried to bend the door frame inwards.. Its pretty tough....
PostPosted: Fri Jul 02, 2010 7:50 am
Give Ash some flowers Nick .
Careful, this could turn into another restoration!
As for the door frame, I have NFI :?
PostPosted: Fri Jul 02, 2010 9:08 am
Are you going to put on new rubber gaskets under the hinge? or will you use something else this time?
those rubber ones look fairly "mushy" did they used to bulge out from under the hinges?
1975 Hairy Lime/White Clubby
PostPosted: Fri Jul 02, 2010 9:11 am
I would go the paper ones before I went with the rubber ones. The paper doesn't tend to deform as much when you tighten up the nuts.
PostPosted: Fri Jul 02, 2010 9:40 am
Im going to replace them with the same style if possible. Otherwise Id need to remove the other door and remove the hinges from the body.... I dont really want to do that... They did mush out a bit but when they were new they were ok. That have been on the car for 9yrs.
PostPosted: Fri Jul 02, 2010 6:57 pm
yeah those rubbers look dire, should prolly do a full resto! :P na i joke. your garage looks spotless, which is not fair
PostPosted: Fri Jul 02, 2010 8:02 pm
Can you get to the rear seats with those sparcos?
PostPosted: Fri Jul 02, 2010 8:03 pm
Mods rock!
DTrain wrote:
.......... your garage looks spotless....
well, he couldn't be doing to much in there then, eh?
PostPosted: Fri Jul 02, 2010 9:42 pm
If the state of your garage is an indication of how hard you work in it, then I'm like a madman on the tools! :lol: :lol:
mooo, I'm a pig!
PostPosted: Sat Jul 03, 2010 2:36 am
Nope, the seats are fixed backs and also mounted to the floor at all four corners. Plus the harnesses prevent rear seat use.
And no... there really isnt a lot going on in there... Until now with doors being pulled off and pulled apart.... I need another project car....
 Post subject: What is it ?
PostPosted: Sat Jul 03, 2010 5:24 am
What is that a blow up spray booth ?
"Let us remove your "SHORTS"
PostPosted: Sat Jul 03, 2010 7:14 am
Image[/quote]
Its one of them protective car bubbles that keeps moisture and foreign stuff out of the car yeah?? Makes me think of seinfeld
PostPosted: Sat Jul 03, 2010 10:00 am
Noooo! It was the Moops :shock:
Dicko
 Post subject: Re: What is it ?
PostPosted: Sat Jul 03, 2010 10:46 am
Nah, Its a Carcoon! Its excellent!!!
PostPosted: Sat Jul 03, 2010 1:01 pm
Mods rock!
Users browsing this forum: No registered users and 117 guests
