It is currently Sun Jul 27, 2025 4:05 am
PostPosted: Fri Jul 02, 2010 9:42 am
So why not help out the guys with older cars?
PostPosted: Fri Jul 02, 2010 8:47 pm
does this then rule out the option of inserting say late 99 model rover doors to pass? i take it this is a no?
Bill
 Post subject: re bars
PostPosted: Fri Jul 02, 2010 10:31 pm
hi Bill
in Victoria and SA its a big NO,
i would assume that in nsw things would be the same
cheers josh
PostPosted: Sat Jul 03, 2010 10:08 am
Josh is correct. To the best of my knowledge the OEM SIB's have never been accepted by an engineer in Australia to satisfy ADR29.
In NSW the SIB's I have seen have all been made of 20 x 50mm blue box with a 3mm wall. I did see some recently from a Qld car that were 20 x 20 square and refered this to our engineer who has yet to inspect them. Additionally I have seem them secured by welding, rivets, bolts and in one case glued.
Chris.
PostPosted: Sat Jul 03, 2010 2:46 pm
By comparison, the factory SIBs are look like they're only about 18 x 2mm tube held in with a single bolt at each end. Completely and utterly pointless in my opinion so it's no wonder they fail out here.
PostPosted: Sat Jul 03, 2010 2:52 pm
Thats what mine has, came from Brickworx like it and past inspection in NSW with no problem. They are also bolted in with grade 8 hex cap bolts.
Cheers Pete
PostPosted: Sat Jul 03, 2010 3:22 pm
Have you ever looked inside an Australian Mini door to see how they passed ADR29? 8)
PostPosted: Sat Jul 03, 2010 3:50 pm
I thought ADR 29/00 didn't kick in till 77 though?
I mean, look at the old 850 doors: no intrusion or inner skins on them!
