It is currently Sun Jul 27, 2025 10:00 pm
 Post subject: Stripped boot hinge
PostPosted: Sat Jul 03, 2010 5:50 pm
I've stripped a thread on the boot hinge closest to the end (the shallow one).
Can anyone tell me the the easiest fix whilts its still on the car?
Next thread size up by looking at tapping charts is M8, that sould like a viable fix?
:D
Thanks.
PostPosted: Sat Jul 03, 2010 6:31 pm
yeah, I did that with one of mine - went up to 5/16 NF
one day I'll put helicoils in them...
PostPosted: Sat Jul 03, 2010 6:51 pm
Not really enough metal there (thread length) to support helicoils so I made some stepped (`bull headed') studs. Also, 1/4 UNF thread should never have been used in alloy, it is a shallow thread and strips too easy. UNC is much better for this as it's deeper.
I bought 5/16" UNC x 3/4" Grade 5 setscrews, and turned most of the length down to 1/4", and threaded it 1/4 UNF.
Then I drilled & tapped the hinges 5/16" UNC.
Be careful doing this, remember the thread axis is at an angle to the hinge face.
I screwed the studs in with Loctite 262 super studlock.
