It is currently Wed Jul 30, 2025 3:31 pm
 Post subject: Torque settings
PostPosted: Mon Jul 05, 2010 7:02 pm
My haynes manual states 60ft/lb for main bearing cap tension and 46 ft/lb for conrod bearing tension.
can anyone confirm if this is corrrect for a 1098? the haynes manual lists these settings listed above for a 998cc, is it the same for a 1098?
also with the cylinder head tension, should i use the settings specified by the haynes manual or the settings from the gasket maker? (ACL)
thanks guys
PostPosted: Mon Jul 05, 2010 7:09 pm
Mods rock!
Main Bearings are 60 ft/lb (tick) but the Big Ends are only 35 ft/lb :oops:
Cylinder Head - what studs are you using? are they new and what nuts?
PostPosted: Mon Jul 05, 2010 7:12 pm
yeh i bought a new set of competition studs and nuts.
so should i re-tension the conrod bolts to 35 ft/lb? is 46 to much?
head gasket is ACL monotorque.
PostPosted: Mon Jul 05, 2010 7:20 pm
Mods rock!
Big Ends - yes, 46 ft/lb is over the top (for standard bolts). 35 ft/lb is the corect factory torque, however if you are using Unbrako Cap Haeds you can go to 42 ft/lbs.
Competition Head Studs and Nuts - what brand? Did they come with any recommendations?
Factory Studs, depending on specifically what they are, vary in torque settings from 40 to 50 ft/lb. The required torque is not dependant on the gasket, the the 'stretch' of the stud.
PostPosted: Mon Jul 05, 2010 7:24 pm
998 & 1098 are same torque settings.
But if you have done the factory 1098 rod bolts up to 46, I would bin them- they are now overstressed.
PostPosted: Mon Jul 05, 2010 9:04 pm
head bolt kit is minispares C-AHT279 and no they didnt have any specs with them in the package they came in.
so the rod bolts are throw aways?
PostPosted: Mon Jul 05, 2010 9:14 pm
I would not trust them now. bolts are cheap, blowups are not. :cry:
PostPosted: Mon Jul 05, 2010 9:17 pm
Mods rock!
If as the Doc says, you've torqued them to 46 ft/lb then YES (I'm surprised they didn't break).
42 ft/lb for that stud kit.
PostPosted: Mon Jul 05, 2010 9:49 pm
thanks guys, will grab some new bolts tomorrow, lucky i checked before i put the box on :lol:
will leave the mains they are fine, will tension conrods to 35 ft/lb after new bolts and head to 42 ft/lb.
thanks guys greatly appreciated.
