It is currently Wed Aug 20, 2025 9:59 am
 Post subject: Crank Damper - MPI
PostPosted: Fri Jul 09, 2010 12:22 pm
I have an AC setup out of a late MPI - yay! but im missing the crank pulley, I have all the other brackets and pulleys etc.
Does anyone know where i can find one? thats not 152 pounds!, I presume some of the Supercharger kits come with a pulley to suit the MPI poly belt?
anyone broken up an mpi and biffed the crank pulley?
Jed
PostPosted: Fri Jul 09, 2010 12:27 pm
Some MPI belts were still V types.
What you're after specifically is a 97 onwards Jap SPI pulley.
:D
PostPosted: Fri Jul 09, 2010 4:54 pm
i've never seen a MPi with V type belt.
i have a MPi pulley, but shipping would be much to expensive, i think
Rover 214 atm ....
PostPosted: Fri Jul 09, 2010 6:26 pm
hey buddy.
my set up is V belt type.
you can take you're compressor and get it changed over to the vbelt type.
any electrical aircon place can do it, or send it away. try go direct, it will be cheaper :)
the pulleys on the sc12 type are v belt type.
pm 92 he may be able to sort you with something though.
