It is currently Wed Aug 13, 2025 6:06 am
PostPosted: Sat Jul 10, 2010 2:33 pm
Gday Ausmini!
When I turn off my clubman, he keeps on firing for a few moments after I turn and remove the key. I read this wasnt good news, but I cant find the thread.
Any help appreciated!
AUsmini is amazing! 8)
Cheers, Ben
- 1974 Leyland Mini S
PostPosted: Sat Jul 10, 2010 2:37 pm
can mean a few things... crap fuel, idling too fast, too hot plugs, buildup of crap in the combustion chambers making hotspots
if it's going to run on, when you switch off, keep your hoot on the brake and stall the motor
PostPosted: Sat Jul 10, 2010 3:01 pm
mine does this too.
I think its a result of the tune it has.
I just let the clutch out if there's someone around if not I just let it run on and have a chuckle.
From what I can gather its not always a bad thing.
blokeinamoke wrote:
PostPosted: Sat Jul 10, 2010 5:09 pm
mine does it on standard unleaded. no issue with high-octane, Ultimate, Mobil 8000 etc.
tim
PostPosted: Sat Jul 10, 2010 5:25 pm
Also the butterfly shaft can be a bit dirty not allowing it to close properly , I just did this on mine its better but I need to do it again
PostPosted: Sat Jul 10, 2010 6:03 pm
Mine did it on normal ULP, put in 98 octane fuel and fixed it instantly :D
PostPosted: Sat Jul 10, 2010 7:00 pm
I was told "running on" after ignition turned off is bad news, like any pre-ignition. Can cause engine damage.
Also caused by over advanced ignition timing & not enough RON in the tank.
PostPosted: Sat Jul 10, 2010 8:08 pm
Same here.
And as AEG said advanced timing will do it.
And carbon build up from running a rich mixture for a while.
PostPosted: Sun Jul 11, 2010 7:48 pm
In an iron headed Mini it just means the C/R is about right in your performance engine.
Yes, I am serious... :lol: 8)
PostPosted: Sun Jul 11, 2010 8:11 pm
Back in the 60's and 70's there was a group of us that had brand new Cooper S's and they ran on even when they were new, some times worse than others, we just used to stall them when it occured. Was pretty common.
PostPosted: Sun Jul 11, 2010 8:45 pm
My wife daily like to run on unless its 98 otherwise just stalls it with the clutch and gets better fuel
Users browsing this forum: No registered users and 314 guests
