It is currently Tue Jul 22, 2025 2:28 am
PostPosted: Tue Jul 20, 2010 3:15 pm
My Master brake cylinder shat itself... which isnt very helpful!
It is a 78 model Leyland so its one of those dual systems (or something like that) not the standard leyland cylinder anyway.
Does anyone know where i can get my hands on one or any idea where i can get a decent rebuild kit for it?
PostPosted: Tue Jul 20, 2010 4:40 pm
just ring kar kraft and order a rebuild kit for it
PostPosted: Tue Jul 20, 2010 5:55 pm
Or a reputable brake shop should be able to do a complete overhaul and rebuild for about $200. includes a stainless steel sleeve and the body is cleaned and replated.
I have had a few done at Brookvale Brake and Clutch.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Jul 20, 2010 5:56 pm
You may also need the proportioning valve to be overhauled as well. :?:
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed Jul 21, 2010 10:04 am
The clubby tandem cylinders are no longer available to buy, but you can get rebuild kits for them:
http://www.minis.com.au/minis/catalog/p ... ts_id=1049
Alternately, you can buy the newer MCs - the same type they had in rovers. But these are a split bore, and you will also need to swap the lines to the proportioning valve.
I'd suggest getting your current one rebuilt and sleeved (but I'm far from an expert). A stainless steel bore will be better than any you buy new, and you know that it hasn't been sitting on a shelf for 20 years with ruined seals.
You can get a reco swap, too:
http://www.minis.com.au/minis/catalog/p ... cts_id=685
PostPosted: Wed Jul 21, 2010 2:46 pm
Mods rock!
As others have suggested, have yours overhauled, don't buy new.
PostPosted: Wed Jul 21, 2010 8:28 pm
The K-7800 repair kit is a PBR, should be available from any decent brake shop.
