It is currently Sat Jul 19, 2025 1:19 am
 Post subject: Help won't start
PostPosted: Wed Jul 21, 2010 8:26 pm
I have put in an electronic ignition and have stuffed around with the carby and now i don't know how to get it to started, is there are starting point on the carby? I have screwed up the jet adjusting nut all the way, how many turns should i go down?
PostPosted: Wed Jul 21, 2010 8:33 pm
15 flats down should get u started
PostPosted: Wed Jul 21, 2010 10:26 pm
Ive always gone 2 full turns out. So 12 flats. Wouldnt hurt to wip your plugs out n give em a clean in case you have fouled them. Have you confirmed you have spark with the new ign system?
PostPosted: Wed Jul 21, 2010 11:01 pm
Ive always gone 12 flats from when it was fluch with the carb body.
Simplify and add lightness
PostPosted: Thu Jul 22, 2010 4:58 pm
The starting point from SU and BMC is 2½ turns.
PostPosted: Thu Jul 22, 2010 5:58 pm
The electronic ignition may have changed your timing, so it may not be firing at the right time. Are you using one of those red hall effect sensors? Mine went straight on and the timing was fine, but yours may well need adjusting.
If it'n not too hard, it might be worth putting your points back on, fixing the mixture and making sure everything else is running fine, and then switching back to the electronic ignition. Otherwise you're not sure if it's the mixture or the ignition that's the problem.
PostPosted: Thu Jul 22, 2010 9:16 pm
just one of the one's from minisport in the UK. How am i to work out if the timint is off? bear in mind i'm a retardo
PostPosted: Thu Jul 22, 2010 9:21 pm
Mods rock!
Problem found
PostPosted: Thu Jul 22, 2010 11:50 pm
why do they not work well?
