It is currently Sat Jul 19, 2025 2:11 am
PostPosted: Thu Jul 22, 2010 4:59 pm
Resident Haemorrhoid
as per the title what's the best and easiest way to repair the battery box i was under the Mini tightening the exhaust clamps and looked over and thought i don't remember the bottom of the battery being plastic. further examination and i realised it was the bottom of the battery i could see with only less than a third of the original battery tray still there :shock:
Lucky i found it when i did or i could of had a spectacular Lucas event :wink:
mtsmini wrote:
Tombo wrote:
PostPosted: Thu Jul 22, 2010 5:04 pm
Drop a new one in - easy enough to do
David L
PostPosted: Thu Jul 22, 2010 5:08 pm
okay , are they a spare part you can get from Mini King or Mini sports?
mtsmini wrote:
Tombo wrote:
PostPosted: Thu Jul 22, 2010 5:10 pm
Yep.
8)
mtsmini wrote:
Tombo wrote:
PostPosted: Thu Jul 22, 2010 5:23 pm
get a bigger battery then it wont fall through the hole
PostPosted: Thu Jul 22, 2010 5:35 pm
Mods rock!
One Mini Specialist used to pop rivet new ones in. I am not sure if that is legal, I prefer to weld them, easy enough, just remember to take the fuel tank out first :shock:
PostPosted: Thu Jul 22, 2010 5:53 pm
just did mine didnt take fuel take out opps
PostPosted: Thu Jul 22, 2010 6:17 pm
I pop rivetted mine - used silaflex around the join. can't see how there would be any weakness - you see when it's out the floor doesn't flex and the little bit of movement is stopped when the new box is in.
David L
PostPosted: Thu Jul 22, 2010 6:51 pm
makes it easier to replace in 10 years time I'd imagine!
tim
