I marked my flywheel while i had it all apart
i also marked the harmonic balancer and timing cover to make it a little easier
if you are unable to fine the mark, you will have to remove a spark plug and use a screwdriver to find when either number 1 or number 4 are on top dead centre. then look through the hole and see if you can see it then. check your harmonic balancer or pulley and see if that is marked.
if not i am not sure how you will find it on the flywheel. is it possible for the flywheel to be upside down?
