It is currently Tue Aug 05, 2025 9:49 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 170, 171, 172, 173, 174, 175, 176 ... 568  Next
PostPosted: Wed Jul 28, 2010 9:39 pm
Got a dirty look from a lady at a round-a-bout. Indicator wasntworking... :oops: Fixed now!
Cheers, Ben
- 1974 Leyland Mini S
PostPosted: Wed Jul 28, 2010 9:45 pm
Looked at the mini and thought to myself.. I might have to bore out the motor and put in the 1098 crank with some new pistons to fit the oversize bore...
PostPosted: Wed Jul 28, 2010 9:54 pm
Ah ..... the joys of Clutch Hydaulics! Sooooooo good having new parts! A joy to drive! Thanks Graham!
Now with 2 extra ports!
scrape, scrub, wash...scrape, scrub, wash..... This was my day...... Removing about 7 thick layers of paint from gearbox casing, clutch housing and clutch housing cover.
Colours ranges from light blue - dark blue - green - red - blue - red - Green
Mini, its in my blood........
PostPosted: Wed Jul 28, 2010 11:40 pm
battery on charge, ready to be taken out for the first time in 2 weeks! can't wait!
tim
PostPosted: Thu Jul 29, 2010 4:22 pm
The stroker just made it home from work in the rain yesterday (cough...splutter).
I forgot that old Lucas dizzys are allergic to H2O. Either that, or the new ballast resistor (on flywheel housing) doesn't like moisture.
Pulsar dizzy on the 1360 didn't have this problem, I could hose the lot with the engine running! :P
[edit] The 45D cap was a bit cruddy outside between the posts, so I've now fitted a cleaned up one wiped inside & out with WD40, and a plastic Coles meat tray as a slush deflector. :wink:
Last edited by drmini in aust on Fri Jul 30, 2010 1:33 pm, edited 1 time in total.
PostPosted: Thu Jul 29, 2010 6:15 pm
Picked up a shell to use for my project. Sadly, it's in very good condition, but has no registration or papers of any sort as it's much better than my shell. But it's at least a Mk III and mines a MkII so my doors wouldn't fit, so it will supply all the panels I need to get my shell back in the pink. Plus if I can find room, I'll keep the rest in case I find time to make a trailer out of the balance of the shell.
PostPosted: Thu Jul 29, 2010 6:47 pm
Mods rock!
I wouldn't care where, a dirty look anywhere, anytime sounds good.....
PostPosted: Sat Jul 31, 2010 11:18 pm
got the last little bits off the doors, really keen to see them kitted out and finished now. So much so that i might finish them off before i start anything else
PostPosted: Sun Aug 01, 2010 2:12 am
I'm being a glutten for punishment and pulling the engine apart. Removed head today, will pull the rest out tomorrow. Why you ask, well it is still blowing a bit too much smoke for my liking and from pulling the head off I can see the bores are pretty well glazed.. Ahhhhhhh good times. Still contemplating bunging in 1098 crank and pistons.. Hmmmm decisions.
PostPosted: Sun Aug 01, 2010 12:39 pm
tried ajusting the rockers with the car in reverse soon found that things are much easer if you rock it in 4th :roll:
PostPosted: Sun Aug 01, 2010 1:39 pm
Finally got a day off work and got to fit a nice HS6 Carby with a shiny new manifold and a great new airfilter. Tuned it all up as per the advice on this forum and whoa....what a difference to the stock 1 1/2 incher and standard manifold. Major improvement.....more than I ever expected :D :D :D :D
1971 Mini K
PostPosted: Sun Aug 01, 2010 2:04 pm
Finally got the engine back in after replacing the gearbox and also installed the megajolt.
Only to find I am missing a couple of spacers and a nut for the manifold, so have to wait another few days :(
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Sun Aug 01, 2010 2:16 pm
ditto on the gearbox rebuild, finally got motor back in car. Now back is fubar and dont feel like starting the car, might have lunch and go back to finish off the final pieces of the puzzle.
PostPosted: Sun Aug 01, 2010 7:06 pm
pulled apart the passenger door catch and mechanism and cleaned/lubricated it - now the door closes with one finger!!
15 minutes very well spent!
Users browsing this forum: i got a mini and 93 guests
