It is currently Tue Jul 22, 2025 3:54 am
PostPosted: Tue Mar 29, 2005 9:30 pm
ok here goes first all the work was carried out by LW parry in sydney ph 9599 2871
they gave me heaps of help and explained everything to me (this was the first time i had built an engine.) but my dad was a mech engineer and he said the machining was really good and was very happy.
* chemical clean of engine and component $55
* messure check inspect & report $27
*remove and replace welsh and gallery plugs $39.60
*rebore and houn 4 cylinder to suit piston $148.50
*surface grind cylinder block face $59.40
*remove and relace cam bearings $36.30
*contour grind 8 cam followers faces $35.20
*demantel and rebuilt & align 4 piston and conrod $48.40
* bore and hone 4 conrod tunnels $66
*crack test 1 cylinderhead $27.50
*recondition & surface grind of 1 cylinderhead $148.50
* remove and replace ring gear (not part of engine rebuild) $27.50
* supply 1 set of pistons and piston rings $244.20
* 1 set of conrod bearings $63.80
* 1 set of main bearings $69.30
* 1 set of main bearings thrust $13.20
* 1 set of gallery and welsh plugs $33.00
* full engine gasket set (1275) $96.80
* 1 competition exhaust valve $46.20
* 1 ring gear $86.90
* remove and replace 4 exhaust valve guilds $22
*supply 4 exhaust valves $28.60
* 8 conrod nuts $44
*Delivery fee $5.50
price exclude GST
TOTAL including GST $1499.30
I got the cam reground later at the same place for $121 including GST
PostPosted: Tue Mar 29, 2005 9:41 pm
cheap zorst valves! Are they one piece?
I paid double that today for zorst valves.
Interesting pricing.....thanx for posting that...very helpfull!
PostPosted: Tue Mar 29, 2005 9:45 pm
not sure it just say competition exhaust valve. it's a s head to.
yeah it was a fair effort typing it but i thought i would help out alot of people and thats what forums are about.
PostPosted: Tue Mar 29, 2005 10:29 pm
thanks for the prices, lots of people wonder but always get the ..."how longs a peice of string" sounds allright to me :wink:
PostPosted: Tue Mar 29, 2005 10:43 pm
8 conrod nuts $44.00??
Chris
Everything I like is either
PostPosted: Wed Mar 30, 2005 6:57 am
Listed price for an S nut is $5.21 each, so yeah..
I would have bought 8 new nuts AND rod bolts.. Chong's busted 1100S motor is a good example of why.. :lol:
PostPosted: Wed Mar 30, 2005 9:02 am
im sure that will be a very helpfull reference to a lot of people thinking about a rebuild, or needing some work done. good idea to post it..
 Post subject: costs
PostPosted: Wed Mar 30, 2005 9:52 am
Did you rebuild your gearbox aswell?
You wouldn't put new engine on old box?
Are you coming down to Gong and Kiama as there will be several new motors taking a slowish drive at varying speeds?
Steve
PostPosted: Wed Mar 30, 2005 12:48 pm
Thanks for that!
$1500 aint scarey at all. 8)
PostPosted: Wed Mar 30, 2005 3:19 pm
Location: Adelaide, then Melbourne, currently N.America, soon back to oz
great work, saves a lot of headaches trying to figure it all out.
sure thought it would have worked out a little dearer than that. good to keep in mind though.
1275LS regrettably sold to move to Canada, but now moving back and need my next mini. - I want a K
PostPosted: Wed Mar 30, 2005 3:32 pm
$1500 is a pretty good price to pay, most of the places i have contacted quote $3000 + before labour!!!
78 Leyland Mini - Prince
PostPosted: Wed Mar 30, 2005 6:30 pm
no i didn't do the gearbox at the time but it's out now to berebuilt. can't make the gong to kiama cruz 2 sick minis that need fixing
