It is currently Tue Aug 19, 2025 5:51 pm
 Post subject: Winter storage advice
PostPosted: Fri Aug 06, 2010 5:20 pm
Rover Cooper
As the topic suggests, what is the best way to store a car over the winter period, I have changed the oil and done the filter, filled all the grease nipples, and put it up on axle stands...
Should I start it on a regular basis, so keep everything lubricated or doesn't it matter, for 3 months.
I have a trickle feed attached to the battery, so thats covered..
I changed the coolant and flushed the system a couple of times.
I run the A/C for an hour on a run to Geelong and back.
Is there anything else that I should be doing to keep the car in tip tip nick.
Now it had the cover over it and just sitting there.
PostPosted: Fri Aug 06, 2010 5:28 pm
keep on driving it that is what you have it for :roll: :roll: :roll: :roll: :roll:
PostPosted: Fri Aug 06, 2010 5:30 pm
Rover Cooper
But it might get wet, and thats just no negotiable....LOL... :wink: :wink:
Its might shrink and its a tight fit at the moment, :cry: :cry:
 Post subject: I suggest.....
PostPosted: Fri Aug 06, 2010 5:33 pm
One of the things I would do is take the battery out of the car completely and put it on the trickle charger "out of the car". Batteries on charge make fumes and these fumes are corrosive and explosive. Make sure the battery is placed in a well ventilated area while hooked up to a switched on Charger. and never sit a battery directly on the ground, put it on a piece of old rubber mat or similar. And spray some WD 40 or INOX in the battery box while battery is out.
"Let us remove your "SHORTS"
PostPosted: Fri Aug 06, 2010 5:48 pm
Mods rock!
In all seriousness, this is actually a good thing to do, move some air through the car to stop it rusting.
PostPosted: Fri Aug 06, 2010 6:09 pm
Check this out www.carcoon.com.au maybe this might help?
PostPosted: Fri Aug 06, 2010 8:22 pm
Tomboss Breweros
I'd go with what Convertible said and remove the battery, the fumes really are bad.
To prevent any condensation inside when i store a car i get those moisture absorbent things and put one inside the car and one in the boot, the refills for them are pretty cheap. I also put them on my lathes with a tarp over when not in use to stop surface rust.
Car covers are good unless you have cats, then they just cause more scratches :roll:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat Aug 14, 2010 3:03 pm
Rover Cooper
Any ideaS ON WHat these moisture absorbent thing are, sound like a good idea
PostPosted: Sat Aug 14, 2010 3:13 pm
Silica gel, they come in packets like teabags, and feel like coarse salt.
Put heaps in...
I use them inside the MIG welder to stop my 12 year old 15kg coil of wire from rusting. :P
If they eventually get damp, put em on a tray in the oven @120C for an hour or so then re-use.
PostPosted: Sat Aug 14, 2010 3:27 pm
Mods rock!
Put heaps in...
I'd suggest some Caution here. There is a General Caution out regarding Silica Gel and in particular Drying out this way. There is a concern that it maybe Carcinogenic as far as I am aware, this concern is still unproven, however the wider industry is moving away from using it.
PostPosted: Sat Aug 14, 2010 3:53 pm
I always have an urge to eat the silicone. It tells me not to on the little bags, but still the temptation is there..
I think you might need ot go get it a little pillow Davo, maybe a Snuggie... :P
I've got a jigsaw over here from Flute.. when are you going to drop by next huh??
Users browsing this forum: Bing [Bot] and 78 guests
