It is currently Fri Aug 01, 2025 9:22 pm
PostPosted: Fri Aug 06, 2010 4:34 pm
I have been working on my car for the last two months trying to get it back to a decent state for the next outback adventure. YAY for my wheel bearings and ball joints arriving.
Will be taking the mini to Kings Canyon this weekend if i get it all finished.
Vote +1 if your also happy you have everything to work on your car this weekend.
YAY :D :D :D :D YAY
PostPosted: Fri Aug 06, 2010 6:25 pm
Will let you know after the weekend. No doubt I will be short some small widget preventing me from finshing.
2008 Prado GXL
PostPosted: Fri Aug 06, 2010 8:50 pm
Likewise.. megajolt ignition system going in.. hope it goes smoothly!
tim
PostPosted: Fri Aug 06, 2010 9:08 pm
I'd just like to see mine at the moment
PostPosted: Fri Aug 06, 2010 9:56 pm
+1, i have all i need to fix numerous cars and bust many knuckles this weekend but its forecast for -1 on Saturday so i might wuss out and sit in my chair next to the fire and watch DVDs :oops:
PostPosted: Sat Aug 07, 2010 7:43 pm
well i had success so far.
i had to take the outer hub up the road to remove the old bearing, it was siezed on there solid. I got the front bearings in.
installed the quadoptics after just confusing myself, taking a break and seeing how easy it actually was.
installed some air horns, now youll hear me damn it.
now i need to sort out the clutch, damn thing has never had enough press in it.
tried to remove front ball joint on the top of the hub, 38mm socket isnt damn long enough. GRRR, went to shop to buy one, not only expensive, couldnt find one anywhere.
and when i was at the tool shop i spoilt myself on a set of imperial kinchrome shifter spanners. Made my weekend a joy :D :D
PostPosted: Sat Aug 07, 2010 7:49 pm
:lol:
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
PostPosted: Sat Aug 07, 2010 8:13 pm
MiNi MuLiShA wrote:
I MAY have got a special envelope in the post... with a BRAND NEW set of 10X6 MAMBAS and A032R soft tyres :D
ahh finally someone has bought some.. how are they? how do they compare to the originals? I assume these are from MWS? look hawt...!
Im torn between these, or force racing split rims... decisions decisions!
tim
PostPosted: Sat Aug 07, 2010 8:16 pm
They are... The bomb!
Awesome finish, very happy!
Fast delivery easy to deal with, perfect finish on the rims.. pitty they run a plastic centre cap, but original spec ones are on there way!
Very happy!
