It is currently Tue Jul 29, 2025 8:11 am
PostPosted: Tue Aug 10, 2010 11:33 am
I was wondering what gasket or seal for bulkhead where the heater hoses enter the cabin (and steady bar bolts to).
I initially thought to use master cylinder gasket (goes under the clutch & brake masters also) but the one I removed is a foam material. Are the standard master cyl gaskets paper or a foam/rubber material?
-Alan
PostPosted: Tue Aug 10, 2010 11:37 am
i use ice cream carton to seal off the holes for the heater hoses. I removed the heater from inside the car. So these are just blocked off. I cut the ice cream carton the same shape as the gasket.
PostPosted: Tue Aug 10, 2010 11:43 am
Hi Alan,
The original Mk1 gaskets I've found are all a foam material, same on the heater fresh air hose blanking plate cover.
Regards
Al
PostPosted: Tue Aug 10, 2010 10:11 pm
I used a foam one too Alan. If you haven't found any yet I'll rumage around my wad of parts receipts and see if I can find where I got them from..
PostPosted: Wed Aug 11, 2010 7:50 am
Mods rock!
Karcraft have them P/N NAM9197. I bought one a little while ago, it was a black foam rubber.
Users browsing this forum: No registered users and 57 guests
