It is currently Tue Jun 24, 2025 4:14 pm
 Post subject: Alloy Timing Plate
PostPosted: Thu Aug 12, 2010 10:21 am
Have been looking for an alloy timing plate (end plate) for my upcoming rebuild,
similar to the MED one: http://www.med-engineering.co.uk/product_details.php?p_id=546&vlang_id=589
Does anyone know of someone in Australia who makes/sells something similar?
Otherwise postage will be a bitch.
PostPosted: Thu Aug 12, 2010 10:26 am
I've got solidworks and a plasma cutter down the road, how many do you want?
PostPosted: Thu Aug 12, 2010 10:51 am
1
Does that make it worthwhile?
PostPosted: Thu Aug 12, 2010 11:03 am
I'll grab 2 if that helps
Mini, its in my blood........
PostPosted: Thu Aug 12, 2010 11:08 am
maybe - I'll rough one out and get a quote.... but it'll be an A type, not an A+ with the extra bit for a tensioner
PostPosted: Thu Aug 12, 2010 3:37 pm
Appreciated Simon.
PostPosted: Thu Aug 12, 2010 7:48 pm
Milatsmadmini
hell ill be #3 for wat its worth
PostPosted: Thu Aug 12, 2010 9:29 pm
arrrm, I dont want to sound like a party pooper but WHY? I gives you no extra HP, you cant see it once installed & it costs money you could spend on far more usefull items. A real waste of time in my opinion. :P
Have a Nice Day.
PostPosted: Thu Aug 12, 2010 10:26 pm
Weight. Every little bit helps.
Am also fitting an alloy head & my current plate is cracked so I need a new one anyway
PostPosted: Fri Aug 13, 2010 4:39 am
I hope the alternator does not vibrate some cracks into its mounting point.
PostPosted: Fri Aug 13, 2010 9:03 am
That's exactly what happened to my original steel one!
PostPosted: Fri Aug 13, 2010 11:45 am
Someone in the US was making really nice ones of these, cheap too!
Can't be @rsed to search but! :?
Sir Alec! we are not worthy!
PostPosted: Fri Aug 13, 2010 2:21 pm
Mods rock!
+1
PostPosted: Fri Aug 13, 2010 4:23 pm
If its that lightweight postage shouldnt be too bad.
And if you get a batch cut then you can sell them off, the more you buy the cheaper it usually ends up per item.
Simplify and add lightness
PostPosted: Fri Aug 13, 2010 6:10 pm
Why not roar a few lightening holes in a standard plate in the appropriate spots so the oil won't get out.....thats what I did to save a few grams. Oh, and visit the toilet before the race, that always gets rid of a bit of weight! :wink:
